It is currently Sat Sep 26, 2026 5:11 am
Post Posted: Thu Dec 01, 2011 4:41 am
Hi guys my rear diff run dry of oil and now the crown wheel is no good are the gears in the front diff the same as i would like to take the front crown wheel and pinon and put them in the rear
any help would be great
Post Posted: Thu Dec 01, 2011 4:43 am
What car are we talking about?
Vehicle: 75 Cruiser
Post Posted: Thu Dec 01, 2011 4:59 am
It's probably "his" car :helloo:
:lol:
Post Posted: Thu Dec 01, 2011 5:31 am
sorry its a sierra ute with 1992 sierra wt diffs in it
Post Posted: Thu Dec 01, 2011 5:43 am
Yep you can.
Post Posted: Thu Dec 01, 2011 9:10 am
thanks guys
Post Posted: Thu Dec 01, 2011 9:14 am
Front centre will go in rear ONLY if it has 26 spline side gears fitted.
I wouldn't recommend fitting a WT front centre to the rear as they are a 2 pinion setup, not as strong as the 4 pinion rear.
NT run a 4 pinion front.
Post Posted: Thu Dec 01, 2011 9:32 am
i have a arb air looker in the rear but just want to take the front crownwheels and pinnon to the back trying not to spend to much as i have just done the gti engine convertion rebuilt the gear box moneys a bit low now so a swap is the best way i think thanks guys for your help means a lot
thanks
Post Posted: Thu Dec 01, 2011 10:54 am
It will work if you put the locker back in the back.
Users browsing this forum: Google [Bot] and 86 guests
