It is currently Sat Oct 24, 2026 12:02 pm
Post Posted: Tue Dec 13, 2011 5:17 am
Ok so here's the hard well for that is off the g16a fuel pump there is this pipe that my finger is pointing at where is it meant to go? Is if fuel over flow?? Cheer for who ever can help it will be very helpful
Post Posted: Tue Dec 13, 2011 5:19 am
to the carby
To the carby?
Post Posted: Tue Dec 13, 2011 5:20 am
There's one you can't see under it that goes to the carb I can't see any other places for it to go unless it goes around the front of the carb I'll upload a pic now
Post Posted: Tue Dec 13, 2011 5:21 am
I'm sure it's the overflow mate.
Post Posted: Tue Dec 13, 2011 5:22 am
Doesnt the overflow hang out the back faceing toward the firewall more?
Post Posted: Tue Dec 13, 2011 5:23 am
Image that's one place its to the right of the bracket
Post Posted: Tue Dec 13, 2011 5:33 am
The first pic goes to carby if you have one under neath the fuel pump, nothing goes on it. It's a overflow pipe or a pipe if it's leaching out of there, it's mean a stuff fuel pump.
Post Posted: Tue Dec 13, 2011 5:38 am
Figured it out anyone near coburg got some fuel line lol
Vehicle: 4wd
First one (with nothing on it) it fuel into carby, the one under it fuel return, and the one with the hose overflow?
Watch out or you'll get sued.
Post Posted: Tue Dec 13, 2011 5:39 am
It's over flow but fuel is pissing out when I crank it over what dos that mean?
And will a g13b pump work on it if it's broken??
Vehicle: Vitara 90'
Post Posted: Tue Dec 13, 2011 6:05 am
No smoking near the car for the time being :blink: :lol:
Sorry I'm not much help.
Post Posted: Tue Dec 13, 2011 6:09 am
Sounds to me like its the one that goes to the carby!
Post Posted: Tue Dec 13, 2011 9:19 am
ok ... depending on the vin number/year there are 2 different fuel pump and carby setups.
if you have 2 pipes on the fuel pump that face to the front of the car , and one that faces to the right hand guard , then the two pipes that face forward go to a block that is part of the accelerator pump assembly.
if you have a fuel pump that has two pipes that face the right hand guard , and 1 pipe facing forward then the top pipe facing the guard is the fuel feed , the one facing forward is to the carb and the bottom one facing the guard is the return ..
the pipe you have in the second picture goes to the purge canister , its a bowl vent. do not connect the fuel to here.
if you have any issues with what ive explained i could put some diagrams up ..
Post Posted: Tue Dec 13, 2011 7:04 pm
Thanks for that mate yer it would help very much I can't see anywhere on the carb where it would go that's why I'm thinking it's return
Post Posted: Wed Dec 14, 2011 5:21 am
I can't see anywhere on the carb where another fuel line goes I was thinking it was return but it's way to big to be a return line it's a 6mm hose any help with pics on where it goes will be much appreciated thanks for the help so far
Post Posted: Wed Dec 14, 2011 6:27 am
These guys R&E auto
Post Posted: Wed Dec 14, 2011 9:18 am
Yer I know that joint go there for most of my parts good place Nice people
Post Posted: Thu Dec 15, 2011 7:54 am
bump can anyone with a vitara with this fuel pump i think its a 88 post up a pic of wherte it runs to please
Post Posted: Thu Dec 15, 2011 8:10 am
here is the first diagram with a carb with a single feed pipe to carb and the return from the pump to the tank
Post Posted: Thu Dec 15, 2011 8:11 am
here is the second that has the fuel pump you are using.
Post Posted: Thu Dec 15, 2011 8:20 am
Ahh cool as bud thanks for that Ive just clicked to why I can't find the other spot for the line it's the wrong pump HAHAHAHA well I guess I need to get the right one luckily i found out now instead of Saturday night thank you very much losfer also where did you find these I couldn't find anything
Post Posted: Thu Dec 15, 2011 8:50 am
its a catalogue of suzuki spare parts i got from work , it lists almost every suzuki part and the price of the parts
Post Posted: Thu Dec 15, 2011 8:57 am
you could probably use the pump you have though , disconnect the two hose facing forward , and leave the feed line attached , crank it over and see where the fuel comes out of , im pretty sure its the top line , connect that to the carb. connect the other to the return to the tank . this should work..
at some stage you(or someone) have changed the carby or fuel pump , i havent really spent much time trying to figure out the difference from one pump to the other , if what i said doesnt work , you will have to change the pump .
Post Posted: Thu Dec 15, 2011 9:17 am
Ohk nah I'll just change it o know it's not broken but it looks a bit taty last thing I want is a busted pump somewhere haha thanks for your help though I'm extremely unstressed now I was about to sell it but now I'll keep it
Users browsing this forum: Google [Bot] and 115 guests
