It is currently Sat Oct 24, 2026 11:13 pm
Post Posted: Tue Dec 13, 2011 1:28 am
Hi guys,
So i've just gotten back from Pedders and been told my Shocks and Bushes (both shackle and eye-hole) on my '92 sierra need replacing and that the leaf springs and steering damper should be changed but not as desperately.
Ideally i'd like to do the 2" OME lift:
http://auszookers.com/index.php?name=Ne ... int&sid=23
But can't afford to do it in one lot and so am forced to look at the alternatives.
The lift in the link above i've priced at $760 + a steering damper
I can get standard shocks for $200 and bushes for $70 but can't find replacement standard springs!
I don't really care about the extra lift, but because i can't find anyone who sells standard springs i'm forced to ask:
1. Is there a shock option that will fit both the standard (sagged) leaf springs i have AND the 2" lifted OME if i eventually get them?
2. Is there a decent standard sized leaf spring available that i've missed in my searching
3. How bad are the ebay kits? Would it be worth buying shocks and bushes for my car now and then replacing the whole lot down the line with something like these:
Blupac
Blupac Basic
Any advice about the questions or suggestions as to how to get these costs done will be very appreciated.
Cheers,
Rob
Post Posted: Tue Dec 13, 2011 1:35 am
Ome 40mm spring. Fronts $162 rears $222
Commo/hiace shocks $120 on special for 4 shocks.
Steering dampener (Gabriel) $40
Plus you said you can get bushes for $70
That's $614
Post Posted: Tue Dec 13, 2011 1:42 am
When i called ARB (Canberra) they quoted me $202 for the front springs, $222 for the rear. Are your prices with a discount or am i being ripped off?
Where are your shock prices from? Super cheap is selling their gabriels for $50 each here.
Also, if i did that, the steering damper and Bushes would be the the only bits i could put in separately right?
Post Posted: Tue Dec 13, 2011 2:09 am
My prices are arb prices for medium springs
Post Posted: Fri Dec 16, 2011 3:22 am
Ok i've decided to wait until i've got some cash then do the full OME lift in one hit after Christmas.
Where is the Commo/hiace shocks special on at zooky?
Also, is the 2" lift going to do anything noticeable to my stability at speed?
Post Posted: Fri Dec 16, 2011 3:28 am
Lovells do a standard height.
I found it improved funnily enough.
Post Posted: Fri Dec 16, 2011 4:11 am
Ask dank and see what he can do for you he helped with a lift kit it was a desert fox 2 inch lifted springs and longer gas shocks bushes and u blots cost me 780 from memory because I picked it up good kit
Vehicle: 1985 Holden Drover
Post Posted: Fri Dec 16, 2011 4:16 am
Gabriel shocks ftw!
1989 WT Sierra.
Vehicle: Jeep
Post Posted: Fri Dec 16, 2011 5:19 am
I would give OME the big miss... try Tough Dog, Dobinson, EFS instead, much better quality, and usually cheaper as well... :D
Vehicle: '94 suzuki maruti
Post Posted: Fri Dec 16, 2011 6:14 am
replaced my OME with EFS fronts, rears are still OME... ive found its a much nicer ride, flexes better but the suzuki lean is much more prominent... overall a much softer spring.
Post Posted: Fri Dec 16, 2011 6:23 am
Anyone have experience with lovells springs? As i said, i don't need the extra lift. Am mostly interested in the best ride for a reasonable price.
Vehicle: Jeep
Post Posted: Fri Dec 16, 2011 6:32 am
Only heard good things abour Lovells springs...
But... Blupac is pretty good gear, i know one Perth Sierra that has the Blupac shockies on it, and they seem to work great, no problems... so if you can afford them, maybe you should get them... :wink: :D
Users browsing this forum: No registered users and 439 guests
