It is currently Wed Aug 05, 2026 4:06 pm
Post Posted: Mon Nov 21, 2011 8:20 am
hey everyone just about at the end of my conversion of a g16b into my sierra. However I didn't get the wiring to the cluster so from the diagram I had I couldn't quite work it out.
So could someone let me know what colors you come up with for the engine light, vss, tacho, I think that's all I'm after??
Post Posted: Mon Nov 21, 2011 8:31 am
when i did mine it was all the same as the sierra colours..ie the temp oil press charge light. vss had to be added
Post Posted: Mon Nov 21, 2011 9:40 am
Yes that's right but I'm really after vss colour and engine light
Post Posted: Mon Nov 21, 2011 10:15 pm
Bump
Post Posted: Mon Nov 21, 2011 10:42 pm
VSS and check eng are usually Violet with yellow trace.
Post Posted: Tue Nov 22, 2011 2:34 am
Do you know the tacho one also??
Post Posted: Tue Nov 22, 2011 3:03 am
tacho is plain brown
Post Posted: Tue Nov 22, 2011 4:52 am
Thought as much just double checking so I don't do any damage cheers guys
Vehicle: 91 sierra, g16b,lift,30's
Post Posted: Tue Nov 22, 2011 7:56 am
so ive got a plain brown wire in my loom where abouts do you hook it up to the tacho
Post Posted: Fri Jan 06, 2012 4:51 am
im still pretty unclear as the what the vss is and the the check engine light??
Post Posted: Fri Jan 06, 2012 5:34 am
whait i have found the vss and found how the check engine light is wired in, im mainly after a throttle position sensor number.... mine is rubbed off, if you have all the following can you post a picture of your code please, its really hard to order something new when you have no code all i keep getting in return is that there is a few to choose from :(
its a 96/97 model engine, mitsubishi computer, three pin MAF meter, 4 pin TPS, 7 pin (i think from memory) distributor this has coil all in one. please help me someone....
Post Posted: Fri Jan 06, 2012 8:13 pm
Bump, anyone
Post Posted: Fri Jan 06, 2012 8:45 pm
because there is.......
I could give you the number of mine & it may not work with your ecu,
Post Posted: Fri Jan 06, 2012 8:48 pm
If you can get the VIN off the car the eng came out of, a Suzuki dealer "should" be able to help.
Post Posted: Fri Jan 06, 2012 9:14 pm
Well its in my sierra, and I do realise that, so that's why I put all my info up so that someone with the same computer etc, please.
Post Posted: Fri Jan 06, 2012 9:15 pm
It runs but not driveable at the moment :)
Post Posted: Fri Jan 06, 2012 10:03 pm
post some decent clear pics of the TPS & someone might be able to pick which one it is.
Post Posted: Sat Jan 21, 2012 6:10 am
Bit of a bump where abouts do u tap the brown tacho wire into from the g16b loom??
Post Posted: Sun Jan 22, 2012 5:04 am
Anyone be able to point me in the right direction? I'm confused as to hook it into the cluster loom or behind the actual instrument!
Post Posted: Sun Jan 22, 2012 5:08 am
The brown wire from the sierra loom isn't used and runs off the old motor to the instrument cluster and this gives you your tacho, but there is a brown wire in the vitara loom that does the same thing you simply have to cut the old wire to the cluster and join the vitara one.
Post Posted: Sun Jan 22, 2012 5:19 am
Thankyou that's the answer I was looking for
Users browsing this forum: No registered users and 194 guests
