It is currently Sat Oct 24, 2026 11:17 am
Post Posted: Thu Jan 19, 2012 5:00 am
For a while now I've always thought i had pretty good brakes, till my recent bearing dramas my brakes dont feel like they are bleeding up properly. are there any tricks like elevating one side of the car or anything like that I should know about.
this is on a SJ50 89 wt sierra
oil lights are like oven alarms, let u know its co
Post Posted: Thu Jan 19, 2012 5:09 am
I rarely even pump the pedal to bleed, jsut let it dribble out
front or back? a loose front bearing will make the brakes pump up, likewise poor adjustment on the rear, they need to be tighter than most people think
Vehicle: 2004 KJ jeep cherokee
Post Posted: Thu Jan 19, 2012 5:10 am
by a brake vacuum bleeding kit, bit expensive but make bleeding so much easier, no pedal pumping at all. use my kit all the time for my motorbikes and the family car. or if ur cheap a large medical syringe and long clear tubing to syphon off with
If at first you don't suceed... lower your standar
Post Posted: Thu Jan 19, 2012 5:44 am
x2 pump it too push the shity fluid out then let it dribble for a while.. do the furtherest bleed nipple last.
Post Posted: Thu Jan 19, 2012 6:06 am
at work i've found those airbleeders dont get all the air out of the system every time if the system had no fluid in it to begin with. I did start out with a syringe cause i had noone else to help but the neighbour jumped the fence and gave a hand to do the pump method which ive found to be the best. I also only gravity bleed if im just putting fresh fluid in the system that was already fluid. are there any adjustments i've got the handbrake set to 5 clicks but i dont think that should affect it?
Post Posted: Thu Jan 19, 2012 6:08 am
thats wierd ive always been taught since being an apprentice (9years ago) always always start furthest away.
Post Posted: Thu Jan 19, 2012 6:18 am
Has your sierra had vitara vented rotors put on the front? This might give you difficulties bleeding the brakes, if you didnt know its been done.
Vit calipers need to be semi removed and flipped up so the bleed nipple is at the highest point.
Other than that, bleeding brakes on a sierra is one the easiest things to do.
Post Posted: Thu Jan 19, 2012 6:27 am
you are right :) furthest point first
Post Posted: Thu Jan 19, 2012 6:30 am
X2 always furthest first
Vehicle: 2018 DMAX
Post Posted: Thu Jan 19, 2012 6:44 am
Make sure u bleed the bias valve or whatever it is on chassis rail. This has casued me issues in the past....
Post Posted: Thu Jan 19, 2012 8:51 am
which line did you crack to bleed it?
Post Posted: Thu Jan 19, 2012 9:00 am
There should be a bleed nipple on it
Post Posted: Thu Jan 19, 2012 9:01 am
On the bias thing there's a nipple on the top bleed that first then the rear I found mine came hood after that plus there a basted of thing if there not bleed you'll have shit brakes if bleed properly your bakes will be good but I've found no matter how much you bleed them the pedel always feels spongy witch I hate
Post Posted: Thu Jan 19, 2012 9:07 am
Royce's gravity feed method needs the closest to far method as the fluid will take the path of least resistance firsthand this will ensure the bubbles are removed. Even the forced method can inadvertantly push a air bubble into an already bled line
Post Posted: Tue Mar 13, 2012 2:01 pm
Is Royce's gravity method anything special/different? There seems to be a lot of conjecture on the Interweb about the gravity method and to start from the furthermost point.
2002 SWB GV
Lifted and Locked
Post Posted: Tue Mar 13, 2012 2:22 pm
I dont even start at a point, I jsut crack whichever I worked on last
Post Posted: Tue Mar 13, 2012 3:29 pm
I know it'll be hard, but ya need to make a friend with someone, and they lay under the car and dash around with the spanners, and you sit in the operators seat,listen to the radio, and pump and hold the pedal....when and if ya hear him.
Ideally the guy under will know what he's doing, but that's not paramount, with brakes you usually know when the job hasn't been done right.
bye
Vehicle: '94 suzuki maruti
Post Posted: Tue Mar 13, 2012 7:08 pm
i only just flushed my brake fluid out tonight... again, everywhere i've read says furthest first. FSM says the same. i used a $15 brake bleeding kit from supercheap. basically a foot of clear tube with a one way valve on the end to stop air coming back up the tube. works fine... put the hose over the bleed nipple, and you can let it dribble out, or if you want to do it faster (which i did since i was getting rid of the old fluid and pushing new stuff through) go and pump the brake slowly.
Users browsing this forum: No registered users and 197 guests
