It is currently Mon Oct 19, 2026 9:24 am
Post Posted: Fri Jan 20, 2012 9:48 pm
Hi all I am getting sick of my gutless fuel drinking 2ltr v6 vitara Lwb now I have fully serviced it new oxy sensors, new coolant temp sensor,new catalatic converter, what the hell is wrong with it, it gets about 250ks per tank doesn't matter how you drive it. It's not throwing error codes this car needs help
Post Posted: Fri Jan 20, 2012 9:52 pm
does it blow any smoke?
changed all our filters?
timing set correctly?
Post Posted: Fri Jan 20, 2012 9:57 pm
Doesn't blow a puff of smoke, changed all the filters havnt checked the timing yet I can't see the timing marks on the timing cover
Post Posted: Fri Jan 20, 2012 9:59 pm
what tires are you running? how long has this been happening? done anything to it before it started playing up?
Post Posted: Fri Jan 20, 2012 10:04 pm
I run 245 75 16s but I put 205 60 16s on it for a week and made no real difference. Ever since I have had it , it has always been gutless but now the fuel usage is getting beyond rediculous driving down the hiway feels like its struggling big time flat out holding 110 especially up a slight incline it kicks back a gear when I think it shouldn't have to its automatic drive it up the highway the tailpipe is red hot almost that hot ya can't touch it
Post Posted: Fri Jan 20, 2012 10:07 pm
Sounds like its running rich or timings to retarded.
Have you tried different fuels? 91,95,98?
Cleaned the injectors? tested fuel pressure?
Vaccum leaks?
Post Posted: Fri Jan 20, 2012 10:12 pm
Yep tryed all the fuels the 98 lasts a little longer but that's it I want to check the timing but I don't know how to get the signal off a 3 wire coil pack and doesn't the diagnostic plug have to be bridged?
Post Posted: Fri Jan 20, 2012 10:18 pm
http://www.auszookers.com.au/index.php? ... c&p=534339
your last thread, Fordem gave some good instructions
Take it to a mechanic that has all the correct gear and get them to reset the timing and clean your fuel injectors and Intake.
Post Posted: Fri Jan 20, 2012 10:34 pm
^^^^ What he said, plus replace fuel filter too if you haven't already done so. If there is still no change I'm guessing timing. How many Kms per tank you getting?
Virgil the Vitara
SV620 Estate
Vehicle: LJ20 LJ50
Post Posted: Fri Jan 20, 2012 10:41 pm
blocked catylatic convertor
take to a muffler shop and get them to check it or just bash the guts out and refit.
Camels have nice toes
Post Posted: Fri Jan 20, 2012 10:43 pm
He just said he has a new cat. The muffler kind.
Vehicle: LJ20 LJ50
Post Posted: Fri Jan 20, 2012 10:53 pm
maybe i should read.... :oops: :oops:
Post Posted: Fri Jan 20, 2012 11:13 pm
I'm going to check the timing but who knows if the chains are on right or it has jumped a tooth because the guy that had it before me apparently changed the chains but didnt do the guides and tentioners what a knob and used the original water pump now it's leaking I have a new timing chain kit and water pump I have herd it's a bastard of a job to do
Post Posted: Fri Jan 20, 2012 11:15 pm
I wonder if the V6s have a problem with the crank pulley like the G16s do? It would be worth checking, as the same problem causes low power problems with G16s.
How many kms has the engine done? Low power usually has me checking the compression.
Post Posted: Fri Jan 20, 2012 11:16 pm
It's done 165000ks roughly
Post Posted: Sat Jan 21, 2012 2:23 am
I checked the timing appears to be about 8deg advanced that should be ok? I'm checking the compression next
Post Posted: Sat Jan 21, 2012 7:31 am
If you go bogger tyres then put 512 diffs under it. Even if not going larger tyres fit the 512 diffs. If you don't, then forget about 5th gear all together. Also use 98 fuel in it and hit it with some injector clean (Double dose for first tank) NEXT TIME you take it for a hwy run of 200ks so it get a good run. After the 3rd tank full you should be getting to notice a performance differance. Take the timing up a bit as well but ALWAYS use 98 Fuel
Steve W
Post Posted: Sat Jan 21, 2012 7:33 am
Even with the small tires it was bad what do the 5:12 gears one in?
Post Posted: Sat Jan 21, 2012 9:21 pm
It will give you better gearing. I feel that they should have come out with them as standard, never met anyone that regreted doing it.
Steve W
Post Posted: Sat Jan 21, 2012 9:30 pm
Gutless as long as youve owned it
Previous owner did a half job on fitting chains
I think we know the answer here :wink:
sometimes you just have to jump in and pull a heap of stuff apart to be sure, rather than fluffing with the easy to get at bits
Post Posted: Sat Jan 21, 2012 9:35 pm
Yea in thinking the same thing I'm going to compression test it first then go from there
Users browsing this forum: Google [Bot] and 205 guests
