It is currently Tue Aug 04, 2026 2:22 am
Post new topic Reply to topic  [ 823 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 28  Next
Post Posted: Thu Jan 26, 2012 10:01 pm
Chop wrote:
Did outdoor auto just got these in?
Not sure how long he's been carrying them. Has a few in stock though.
Post Posted: Thu Jan 26, 2012 10:02 pm
Are these chinese copies or the real deal?
Post Posted: Thu Jan 26, 2012 10:16 pm
Real deal
Post Posted: Thu Jan 26, 2012 10:27 pm
Sweet 8)
Post Posted: Sun Jan 29, 2012 7:23 pm
rightO trailer crew... am i going to regret not putting in a flip top lid?
i've got it all sussed out & have everything ready to go apart from the over centre catches, i'm just thinking it's a whole lot more shit to stuff up.
i'm thinking about just bolting the lid down, seeing i'm not going to be carrying a great deal apart from a spare tyre. :?
this is what i got from the wreckers & some brackets i found in the bucket of bracketometry.
i'd like to still be able to use it as a trailer & having all the struts, brackets n shit will make it hard to make it removable, i'm thinking some sort of weather seal & bolting it down.?
Post Posted: Sun Jan 29, 2012 7:45 pm
Mines just bolted down, with a weather seal.
Though weather still gets in.
But anything that needs to be dry travels in the car.
Mines just 4 bolts and its off.
Use mine as normal trailer a lot.
Spare tyre will fill it anyway.
I don't put anything in trailer thatb I need to use a lot.
And everything goes on a tarp, so I can just slide it out.
You could try a big roll.slide out draw,
that could be removed when camper top not on
Post Posted: Sun Jan 29, 2012 7:48 pm
Vehicle: 4wd
Post Posted: Sun Jan 29, 2012 7:56 pm
I like the idea of removable and the idea of hinged for internal access.
What about bolting the timber down like christover and having a cutout section on hinges for internal access? I guess the tent would have to be erect and it would just be a case of lifting the mattress for access.
Watch out or you'll get sued.
Post Posted: Sun Jan 29, 2012 8:07 pm
I was thinking same before I got my tent top.
But I finished up buying one with an insulated floor,
of alloy sandwiched poly styrine.
Insulation and lighter weight being main reasons.
No way of doing that with this type.
Post Posted: Sun Jan 29, 2012 8:13 pm
i'm thinking hinged, with removable hinge pins & a broomstick to hold it , rather than having all the brackets & gas struts permanently fixed to the trailer?
i think that's how Moph has his set up.... Keep It Simple, Stupid.
Post Posted: Sun Jan 29, 2012 8:23 pm
I vote for the lift up lid, you've done this much work it so what's a little bit more :wink:
The one thing that shit me with the blue trailer was getting stuff out from under the tent
Post Posted: Sun Jan 29, 2012 8:31 pm
The work never stops anyway.
Still doing little things to mine as I live with it.
Getting everything exactly right first go is rare.
More fun modding and working on something when you can use it.
Vehicle: LWB Sierra & XL7
Post Posted: Sun Jan 29, 2012 8:35 pm
Put a couple of tec screws to hold the strut bracket down, when you need to take your top off, Its as easy as taking the screws out with a spanner, same as the hinge side.
'92 Vitara & Camper trailer
Post Posted: Sun Jan 29, 2012 8:42 pm
Or you could just buy struts with ball cup ends. Thats what mine has so the lid comes off easy :wink:
Post Posted: Sun Jan 29, 2012 8:46 pm
the thing is i keep finding more shit i could do...
today i was thinking about putting a 12v power to it just using a rechargeable jumpstarter pack, LED strip lighting, the list goes on & on... but again it comes back to more shit that's going to get in the way if i want use it as a trailer & the heavier it gets.
i'm not planning on having to much under the tent apart from a spare tyre & maybe my toolbox, fuel, water when doing the longer trips.
Post Posted: Sun Jan 29, 2012 8:47 pm
:roll: :lol: it's not a sierra... i was going to use nuts & bolts. :wink:
Post Posted: Sun Jan 29, 2012 11:39 pm
if you want to use it as a trailer, what are you going to fit in it anyway? :wink:
IMO keep it as a camper and hire a bigger trailer if/when you want a trailer :mrgreen:
or just come get one from up the hill
Go Hard, Trailer Home
Vehicle: 93 Sierra
Post Posted: Mon Jan 30, 2012 1:31 am
Yep that's it ... I have three hinges on one of the long sides, with removable pins. Knock them out and the entire top comes off. I have 3-4mm thick self-adhesive foam seal strip from Clark Rubber around the top which does a pretty good job of keeping dust and rain out when it's closed up too.
Re the other stuff like lighting etc, I once had plans for all that too. Then I realised I'd be better off spending the time it would take me to set all that up actually using the camper instead, and lost all interest ;)
Post Posted: Mon Jan 30, 2012 7:14 am
If all you're going to put in it is stuff that you won't often want to access I'd just bolt it down.
I keep all of our camping gear in the trailer so I don't have to store it in the house plus we're ready to go pretty quickly. As you know I've got access on all four corners plus the tailgate and still find it impractical to not have a flip up lid.
Post Posted: Mon Jan 30, 2012 12:00 pm
what sort of latches have you used to hold it down?
Vehicle: 93 Sierra
Post Posted: Mon Jan 30, 2012 1:57 pm
Sorry ... could only find a large pic in Google images. Ones like this with a relatively long shank so that they go through the 19mm ply, then the latch closes across the top and can be padlocked in place. Couldn't use the strap type ones easily with my trailer sides, so went with these. They work well and with sealing foam around them haven't let water into the trailer yet - note that they're located just under the edge of the tent skirt, so protected from direct rainfall anyway.
Post Posted: Mon Jan 30, 2012 5:59 pm
I have this style on the pod, adjustable and lockable with a padlock. I might have more surface area for that to be fitted to the lid though.
And i have the style above that Moph put up on the tailgate which is also lockable
Post Posted: Mon Jan 30, 2012 6:12 pm
cause of the folded edge of the trailer i don't think i can run that style of over centre latch as the wall of the trailer is about 50mm in from the folded edge.
i think i'll be stealing Moph's idea. :wink:
Post Posted: Mon Jan 30, 2012 11:11 pm
they are called antiluce fasteners :wink:
http://uesint.com/product/fasteners.php
Post Posted: Tue Jan 31, 2012 7:14 am
I also used the same fasteners for my side access panels but the "weld-in" version.
Post Posted: Tue Mar 06, 2012 7:52 am
Thanks Steve for great video.
Out testing in Victorian High Country.
No water got into tent or bedding.
A bit got into trailer tub, though.
Only problem off road was when I'd only locked one hub.
Reversing ain't no fun, but acceptable.
Post Posted: Tue Mar 06, 2012 8:07 am
Cool. I think that's the first "Trailer in action" vid... or have I missed one?
Post Posted: Tue Mar 06, 2012 8:38 am
Good question, must do a search later.
Plenty of stuff on you tube with trailers.
Video makes everything look easier, and less scarey :)
Post Posted: Tue Mar 06, 2012 8:50 am
nice work Chris, looks like it works well behind the LWB 8)
pretty sure that's the first AZ trailer vid Armsup
Post Posted: Tue Mar 06, 2012 8:53 am
Yours is next then :)
Users browsing this forum: No registered users and 20 guests
