It is currently Sat Oct 17, 2026 5:13 pm
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3
Post Posted: Fri Mar 09, 2012 5:28 am
cheap fix and will tell you how bad the rate on those springs are-
as shep said fit stock shackles again , and get some angle back on the shackles so the springs can start to work correctly
Vehicle: '94 Sj413, 1.6 baleno convert
Post Posted: Fri Mar 09, 2012 11:44 am
My spine is fine, don't worry, I've been sticking to the bike instead for my daily driver/ hooner. ;)
Ok so options are:
1. Refit the stock shackles to improve shackle angle (does this mean removing the reversal kit? cause that's not gonna happen, welds and all ;))
2. Remove a leaf from the pack to loosen the springs up.
3. Both.
Thanks again for the help!
Post Posted: Fri Mar 09, 2012 12:34 pm
Stock shackles will do very little to improve that shackle angle considering they are completely vertical now. You need to remove leaves to flatten out the pack to get more shackle angle. And those front (reversed) shackles aren't that long, I have them on my zook.
Post Posted: Fri Mar 09, 2012 1:44 pm
Thats what I was thinking, the springs will affect the shackle angle more than the length as they are nearly vertical.
The only other way to improve the angle would be to cut and move the shackle mounts (which I could do) but then I suppose the springs will still be too tight regardless.
Will have a look at removing a leaf then - is it safe to remove 2 leaves if necessary (leaving me with only 2 leaves on the spring)?
Post Posted: Sat Mar 10, 2012 3:17 pm
2 leaves is pushing it I think, you might find that it leans like a bitch when you sit in the drivers seat with only 2 leaves.
Post Posted: Fri Mar 16, 2012 11:16 am
Update on this.
Found a guy selling some new shocks that well exceed my current and forseen flex for 400 so will be picking them up around easter time.
Did some proper wheeling the other day and got it to flex alot better (same config, no changes yet) so I will be looking at fitting 32x10.5 Maxxis bighorns if possible and go wheeling again to see if I'm happy with the flex.
In the mean time, I will have a look at options to get a better shackle angle.
Users browsing this forum: Google [Bot] and 209 guests
