It is currently Mon Nov 02, 2026 12:19 am
Vehicle: chick magnet coily
Post Posted: Fri Mar 09, 2012 7:19 pm
hi everyone,
i just bought a 1997 coily and was wondering if there is any thing i should brace/replace :?
on it befor i go wheeling so far i have:
30"x9.5 maxxis buckshots on sunraisia rims (15x8) :D
alloy roll and bull bar
also is there any mods i can do at all
any help is apreciated
when in doubt... HOLD IT PINNED!!! :)
Post Posted: Fri Mar 09, 2012 7:24 pm
Budget?? Suspension, swap bar removal, t'fer gears
Post Posted: Fri Mar 09, 2012 7:31 pm
im limited to first year aprennis wages
hav already removed swaybar
i hav been told i need to brace controll arm mounts?
Post Posted: Fri Mar 09, 2012 7:35 pm
Brace every mount on the diffs, including panhard.
Post Posted: Fri Mar 09, 2012 7:47 pm
would you happen to have any pics as i am new to this?
Post Posted: Fri Mar 09, 2012 8:01 pm
Brace all the radius arm mounts on both the diffs.
Reinforce the shock towers.
Swap in a gear driven transfer.
Buy a leafy.
Post Posted: Fri Mar 09, 2012 8:27 pm
how do i Reinforce the shock towers.
Post Posted: Fri Mar 09, 2012 9:03 pm
Weld a 2 or 3 mm washer over the top of it. Big enough to cover the top of the strut mount and with an appropriate sized hole for the strut thread
Post Posted: Fri Mar 09, 2012 9:21 pm
Bring it to my place and I'll do it for you. Done plenty of the shitboxes, so whats one more :thefinger:
Costya a 6pack of bundy. (Thats cheap!) :wink:
Post Posted: Fri Mar 09, 2012 9:23 pm
On the topic,
You can do things like diff breathers, headlight upgrade, LED interior light, and reverse light (camp light), general maintenence.... Heaps of low budget stuff you can do.
Post Posted: Fri Mar 09, 2012 9:36 pm
This is heaps easier than my idea pompoms
Post Posted: Sat Mar 10, 2012 5:52 am
thanks so much guys i got a LED interior light (lights) it lights up my whole car 8)
and ill start makin a reverse light today :? as for breathers what is the best hose to use?
also fatzook any chance you could brace my difs aswell? :roll:
Post Posted: Sat Mar 10, 2012 5:58 am
It's his favourite job... pompoms
Hose for breathers. I used garden hose, 95% of the people on here will disagree. Mainly because it isn't oil resistant :roll: I have had garden hose on my car for 2 years and it has worked a treat :peaceout:
Post Posted: Sat Mar 10, 2012 6:27 am
awsom mate do you hav any pics of your diffs?
just so i can see what you mean
Post Posted: Sat Mar 10, 2012 6:47 am
My front diff is from a leaf sprung Sierra. The rear is standard coily...unbraced :( The mounts just get swapped for a thicker material 3 or 5mm
Post Posted: Sat Mar 10, 2012 6:52 am
My front diff is from a leaf sprung Sierra. The rear is standard coily...unbraced The mounts just get swapped for a thicker material 3 or 5mm
why a leafy front diff and does the rear need bracing?
Post Posted: Sat Mar 10, 2012 6:55 am
Because I wanted to piss off the struts and radius arms, the other bonus is I now have cromo cv's/axels and a lokka Armsup
Post Posted: Sat Mar 10, 2012 7:10 am
Post Posted: Sat Mar 10, 2012 8:08 am
Only ever had a problem with my rear diff. I think this is because the rear of a coily works a lot better than the front...suspension wise, therefore it creates a lot more stress on the mounting points. JMO though :wink:
Post Posted: Sat Mar 10, 2012 12:19 pm
Not on 1st year apprentice wages :wink:
You're welcome to swing by, and I can talk you through what you do and don't need, and what you can get away with short term.
Post Posted: Sat Mar 10, 2012 12:52 pm
how much would you charg for the front diff and strut reinforcement
Post Posted: Sat Mar 10, 2012 7:39 pm
ok so i made up a reverse light (150w) 8)
polished my bull/roll bar :blingbling:
attempted fender flares (epic fail :oops: )
ripped my soft top :x
and installed 2 150w spotties :D
what other easy mods is there?
Post Posted: Sun Mar 11, 2012 7:41 pm
Auszookers sticker
Sj80,31 claws, lift, winch, 6.5
Post Posted: Mon Mar 12, 2012 4:19 am
on its way ;)
Users browsing this forum: Google [Bot] and 44 guests
