It is currently Sat Oct 31, 2026 10:26 am
Vehicle: MG410 1.6efi broken rear diff
Post Posted: Fri Mar 09, 2012 10:41 am
Does anyone know much about the DOMINATOR LSD like quality & reliability or is it better to go for air locker.At present I'm not going anywhere until I work out a diff centre fix
Thanks
Ian
Post Posted: Fri Mar 09, 2012 1:45 pm
Not many people opt for an LSD in a zook. If you can afford an Air-Locker then that is your best option.
Post Posted: Sat Mar 10, 2012 3:00 pm
An LSD is not and never will be a locker.
Post Posted: Sat Mar 10, 2012 3:26 pm
I've had a LSD on a holde 1tonner, but never really undertood what it does.
Explain please.
bye
Post Posted: Sun Mar 11, 2012 10:19 am
Explain please.
bye
LSD is a Limited Slip Differential, all it does it limit the amount of difference in wheel speed between the two wheels. they are good for on-road and if tight enough good for easy off-road work. they do not 'lock' the wheels together so the wheels can rotate at different speeds.
Post Posted: Sun Mar 11, 2012 12:01 pm
shandy92 wrote:
Explain please.
bye
Shandy has kind of got it, but obviously has not owned a good LSD in a light car likea suzuki, yes they are not a locker but a good tight lsd is an awesome compromise. It wont give you 100% lock up but will make a huge difference to the capability of your vehicle. To give you an idea many years ago my brother blew up his LJ a few weeks before heading off on holidays to Faser Island, I lent him my LJ for the holiday it had a new lsd in it. When he came back he said that my LJ went well, I asked him what he thought of my free wheeling hub conversion on the hiway, he hadn't realized that I had free wheeing hubs(LJ's dont have them) and had not engaged them so drove around Fraser for 2 weeks selecting 4x4 but only still being in 2wd.
Vehicle: 2018 DMAX
Post Posted: Sun Mar 11, 2012 12:06 pm
I found this write up the other day well googling Dominator LSD's, some good info on some of the different types of LSDs and there function.
http://outbacktravelaustralia.com.au/do ... lained.pdf
Post Posted: Sun Mar 11, 2012 12:20 pm
This is a good explaination I just looked up for you.
The clutch-type LSD is probably the most common version of the limited slip differential
This type of LSD has all of the same components as an open differential, but it adds a spring pack and a set of clutches. Some of these have a cone clutch that is just like the synchronizers in a manual transmission.
The spring pack pushes the side gears against the clutches, which are attached to the cage. Both side gears spin with the cage when both wheels are moving at the same speed, and the clutches aren't really needed -- the only time the clutches step in is when something happens to make one wheel spin faster than the other, as in a turn. The clutches fight this behavior, wanting both wheels to go the same speed. If one wheel wants to spin faster than the other, it must first overpower the clutch. The stiffness of the springs combined with the friction of the clutch determine how much torque it takes to overpower it.
Getting back to the situation in which one drive wheel is sliping or off the ground and the other one has traction: With this limited slip differential, even though the wheel off the ground is not able to transmit much torque to drive, the other wheel will still get the torque it needs to move. The torque supplied to the wheel that is off the ground is equal to the amount of torque it takes to overpower the clutches. The result is that you can move forward, although still not with the full power of your car.
Post Posted: Sun Mar 11, 2012 12:48 pm
Thanks for the info as I can get new Dominator LSD for third the Price of a Air Locker delivered,and I still have front auto locker it could be a good option to replace rear auto locker (broken a pin or side gear) until back in city.
I should note I understand LSD Function just not familiar with this brand ir any other for the Sierra,
As I need to complete diff repair in the scrub which is not the ideal location especially Air Locker Locker setup as I'm over 500km from Kalgoorlie.
Post Posted: Sun Mar 11, 2012 5:06 pm
2stroker wrote:
shandy92 wrote:
Explain please.
bye
Got any details on said LJ LSD?
Vehicle: 2018 DMAX
Post Posted: Sun Mar 11, 2012 5:16 pm
sideways wrote:
2stroker wrote:
shandy92 wrote:
Explain please.
bye
I would be guessing one of those elusive Carry LSDs...
Cusco was selling these new in 2009(I have a '09 catalogue) but unsure if they still produce them..
Post Posted: Sun Mar 11, 2012 5:48 pm
I bought two new from Mr Off Road at Enoggera in the early 90's I still have one in my LJ, Calmini still sold lsd's for LJ's/1litres till a few years ago
Post Posted: Mon Mar 12, 2012 6:24 am
Where from and how much? ( if you don't mind me asking)
Post Posted: Mon Mar 12, 2012 6:53 am
$400 on eBay...
http://www.ebay.com.au/itm/SUZUKI-SIERR ... 4ab4ea95d1
Post Posted: Mon Mar 12, 2012 1:41 pm
A quick search uncovered this
http://www.jeep4x4center.com/calmini-sj ... s54ls.html
 Profile WWW ICQ YIM
Post Posted: Mon Mar 12, 2012 1:52 pm
matfan wrote:
I enquired about the calmini LSD some time ago, and was told they were no longer made. Not sure if this is stil the case :?
Post Posted: Mon Mar 12, 2012 2:25 pm
I think they may have cocked up there because every other shop on the net that I can find says either not available or temporarily unavailable...
 Profile WWW ICQ YIM
Post Posted: Mon Mar 12, 2012 2:46 pm
Calmini have had 'Unavailable' on their own site for years now.
http://www.puresuzuki.com/Limited_Slip.htm
Post Posted: Wed Mar 21, 2012 10:16 pm
WARNING.............................
I told a mate about these after reading this thread, he bought one and it has arrived yesterday, it went to Darren at B&P to have it fitted today, turns out it is a vitara LSD not sierra as advertised, my mate Craig has contacted the supplier and they have said tough luck no refund, he is onto EBAY about it to complain and try to get his money back, he payed via paypal.
Users browsing this forum: Google [Bot] and 186 guests
