It is currently Mon Oct 19, 2026 5:53 pm
Vehicle: 02 GV SQ625 + 84 Sierra SJ410
Post Posted: Wed Mar 14, 2012 10:43 am
Changing flywheel as a while back a bolt broke off and had to drill+easyout to get it out.
Obtained a second hand flywheel. Going to get the spare flywheel machined by the machine shop.
Some questions
1. While the gearbox, clutch and flywheel are out is there anything else I should do while they are out? Is there a oil seal behind the flywheel or anything?
2. Is a clutch something that an amateur should replace themselves? (Is there any calibration that needs doing or is it all bolt on)
3. IIRC to take the flywheel off you need to remove a massive nut don't you? Is this nut likely to be as tight as the flange nuts on a 30 year old transfer case? Any tips?
Post Posted: Wed Mar 14, 2012 11:50 am
scorpydude wrote:
1. While the gearbox, clutch and flywheel are out is there anything else I should do while they are out? Is there a oil seal behind the flywheel or anything? Yep Rear Main Seal
2. Is a clutch something that an amateur should replace themselves? (Is there any calibration that needs doing or is it all bolt on) It's not all that hard and it's a good experience for an amateur (being one myself I should know :P)
3. IIRC to take the flywheel off you need to remove a massive nut don't you? Is this nut likely to be as tight as the flange nuts on a 30 year old transfer case? Any tips? Not one massive nut, lots of normal sized nuts. A rattle gun will come in handy here. Saying that, I did my last one at night and I didn't want to piss off the neighbours with the compressor so I did it with hand tools.
 Profile WWW ICQ YIM
Post Posted: Wed Mar 14, 2012 1:40 pm
Remove gearbox. [10 & 12mm sockets, 14 & 17mm spanners.]
Remove clutch and pressure plate. [12mm socket.]
Remove flywheel. [17mm socket]
Remove rear main seal housing. [10mm socket]
Replace rear main seal.
Refit rear seal housing.
Remove spigot bearing in flywheel.
Replace spigot bearing. (a lot easier with flywheel on bench than in car)
Refit flywheel.
Refit clutch and pressure plate.
Grease the throwout snout on the front of the gearbox. The bit the bearing slides on. Replace the bearing if it feels notchy.
Refit gearbox...
Post Posted: Wed Mar 14, 2012 1:54 pm
Thanks guys!! Just what I was after.
Post Posted: Wed Mar 14, 2012 10:00 pm
Forgot this bit first:
Drain engine oil.
Remove sump and gasket.
And then this after:
Trim rear seal housing gasket flush with block, seal with RTV Silastic.
Re-install sump with new gasket.
Fill with oil.
Post Posted: Wed Mar 14, 2012 11:26 pm
Drain engine oil.
Fill with oil.
Nah... just park it facing downhill..... :rofl:
Post Posted: Thu Mar 15, 2012 10:26 am
I would replace the clips that hold the thrust bearing on the gear box.
On a 1.0 litre, these are a common failure, needing gear box out to fix.
Probably wise to do get a new thrust bearing, too.
Post Posted: Thu Mar 15, 2012 10:29 am
Thanks.
I've never actually seen behind a flywheel before. Can you please explain the reason for this step a little more?
Are you just saying it's worth replacing the seal housing gasket while I replace the seal? And that the seal housing gasket will need to be trimmed a little from within the area that the sump covers?
Ah, good idea. Thanks. Will do.
Post Posted: Fri Mar 16, 2012 2:31 am
Thanks.
YES
The gasket surface for the oil seal housing to the block, and the sump to the block are at right angles to each other. 2 Gaskets like this cannot provide an oil-tight seal, so a bit of silicon is required. The 1.3 dodged this problem by using silicon to replace the whole sump gasket.
The oil pump at the front of the block is also the same arrangement, but you shouldn't be disturbing that.
Here's the bit from the manual:
Vehicle: '91 Sierra, Fluffy Dice.
Post Posted: Sun Mar 18, 2012 3:35 pm
Do you have a clutch alignment tool?
If at first you don't succeed, get a bigger hammer
Post Posted: Sun Mar 18, 2012 4:53 pm
No. is it important?
Post Posted: Sun Mar 18, 2012 7:32 pm
Not really needed.
Just run your fingers around the gap between the flywheel and pressure plate and make sure the clutch plate is centred then eyeball the clutch splines against the spigot bearing.
Post Posted: Sun Mar 18, 2012 9:28 pm
It's not critical but it is a smart thing to do if you're not confident, otherwise use a broom stick and file it down. Clutch has to be exactly centered.
Post Posted: Mon Mar 19, 2012 7:45 am
Don't scare him like that!!
Don't worry about the tool, don't worry about the broom stick, sit your head up in the trans tunnel and just eye-ball it.
 Profile WWW ICQ YIM
Post Posted: Mon Mar 19, 2012 8:43 am
I found a good video on the topic, easy to understand. Will give it a shot!
Post Posted: Mon Mar 19, 2012 9:13 am
I'm sure you'll manage just fine
 Profile WWW ICQ YIM
Post Posted: Mon Mar 19, 2012 4:12 pm
While you're down there inspect the lever that the clutch cable attaches to, they tend to crack at the end that goes onto the splined shaft but can be easily welded.
Users browsing this forum: No registered users and 177 guests
