It is currently Wed Oct 28, 2026 4:00 pm
Vehicle: sierra sj70 1993
Post Posted: Tue Mar 20, 2012 8:19 pm
i took my suzuki swimming andwhaen i did it went pretty much top of the bonet i had no snorkel and stoped completly after that the alternator wasnt working but has now dryed up it wasruning pretty good after a week i changed the oil but noe it is starting to run ruff not ideling just tell me what i might of done to my engein??
dont get mad get muddy
Post Posted: Wed Mar 21, 2012 6:52 am
fuel tank is probably full of water
if water got into teh sump all manner of stuff could be broken
Post Posted: Wed Mar 21, 2012 7:54 am
Could be any number of things. Please in future attempt to write with a little grammar.
Post Posted: Wed Mar 21, 2012 8:12 am
Drop the tank and empty it out and blow the fuel line s out with a air gun change filters
Open up and clean and spray all the electrical
U might have water in dissy or plugs
Post Posted: Wed Mar 21, 2012 8:22 am
Yep this is a common one here. The rigs fair well after a dunk, but act up a few days later. Usually it is water/mud ingress from the fuel tank vents, and nothing short of a fuel tank drop , and line flush/blow out will solve it.
Be ware that if any sand or mud got in the fuel lines your carby/injection may need a jet/passage clean as well.
A lot of times it is water in the electrics too (distributor cap, plug wires, ecm etc).
Post Posted: Wed Mar 21, 2012 8:34 am
Please in future if you have nothing useful to add other than going against the one main rule of this place STFU and dont post.
Post Posted: Wed Mar 21, 2012 10:15 am
I didn't think there were any rules in this place other than what you feel like imposing at any given moment. At least that's the impression I get, sorry I didn't think professionalism was your forte.
Post Posted: Wed Mar 21, 2012 10:21 am
I liked it a lot better when you pissed off to wherever you pissed off too, you should consider going there again
Post Posted: Wed Mar 21, 2012 10:58 am
I like your sense of humor Royce, I expected a banstick beating.
Anyway for what it's worth SJ70 Suzuki I'm assuming you have a stock 1.3L carby Sierra as you didn't give any more details so that rules out things like TPS and airflow meters affecting the idle. My first (and probably the easiest) place to check would be the dizzy cap, give it a good clean with contact cleaner and the plug lead ends wouldn't hurt to. If the motor did ingest some water the air filter could be caked up with muddy water choking the motor so check that. The fuel tank, pump, lines and filters like others mentioned would be my next place to look. Failing that then I'd be changing fuel filters, flushing the fuel tank and lines with the feed to the carby disconnected like others mentioned. Then if you still had dramas I'd probably replace the plugs before finally having the carby looked at, just because plugs are cheaper and easier than a carb rebuild.
Vehicle: On the lookout
Post Posted: Wed Mar 21, 2012 12:06 pm
Ok, I might get flamed for this, but TOPGEAR of all shows (facepalms himself) drowned a Sierra and it was blatently obvious right away that the tank was filling with water. Air bubbles and everything. If the filler dipped below the water line I'd be fairly certain it's time to drain the tank. Looking at everything else first is kinda wrong priority order. But then we werent there when you drowned, so ask yourself if the filler dropped below the waterline or not.
Crispy old grand vitara
Post Posted: Wed Mar 21, 2012 12:09 pm
don't know if you've noticed, but no one ever picks on grammar or spelling around here, that is unless you type like you actually drank the bong water & are posting on boostloosing.
Post Posted: Wed Mar 21, 2012 1:09 pm
Sorry then but I found the original post genuinely hard to read, I don't expect perfect grammar, mine sure as he'll isn't. But a 30 second proof read helps everyone out.
And I listed fault finds in order of ease and cost with actual known problems in mind. If you know for sure the filler went under then there will be some amount of water in the fuel system.
Post Posted: Wed Mar 21, 2012 1:39 pm
I would say about 90% of the guys here take one look at their carbs and try to "Eliminate all those damned un-need vacuum lines" (L-O-Fucking-L) "get rid of that stock junk electric carb thingy", or "ditch that crap for a webber"
Anyways... what happens most of the time is that they disconnect that "useless" vent line leaving it open. They usually don't notice a problem until they get about frame deep in water. Then they have the same issue you are describing.
What I am trying to say, is that if your return or vent line is old or the charcoal canister (did you guys get those?) line is brittle, cracked or generally not seated well, mud and water can infiltrate there too. The vent line, tank return and charcoal canister all connect well below the tank at the frame, so you don't have to get that deep to end up with crp in the tank.
I like the list above though, a logical order of ease and price first, is always the way I like to troubleshoot.
Post Posted: Wed Mar 21, 2012 4:02 pm
I would get the fuel tank cleaned as most suggested and change the fuel filter while you're at it
Im sure it was his dodgy iPhone playing games and auto-correcting.
BTW - ....mine sure as he'll isn't
He'll = He will
Vehicle: 93 Sierra 2'' lift 30'' tires
Post Posted: Wed Mar 21, 2012 4:11 pm
the exact same thing happened to me, ran fine for a week and then just wouldnt idle unless you are revving it. Change all filters and oils like everyone else said and clean out your fuel tank. I ended up having to get a different carby and that fixed it.. swimming has never been so expensive :P
Post Posted: Wed Mar 21, 2012 4:22 pm
Haha that actually is my iPhone autocorrecting hell, apparently it's a naughty word :/
Users browsing this forum: Google [Bot] and 284 guests
