It is currently Sat Sep 26, 2026 11:06 am
Post new topic Reply to topic  [ 192 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
Post Posted: Mon Apr 09, 2012 5:15 pm
BertZook wrote:
whts the problem with bolt-on aftermarket mods??? :?
Im sorry but not everyone here has the experience/knowledge/tools to do a custom job.... or the money to paid to someone to do so
Nothing wrong mate. But alot of people just buy them for appearance sake. And thats fine too. I just think that there are alot of people who don't look past the cool factor of big lift, to see the harm it has on drivability of a vehicle that is not designed for that sort of elevation. :|
Post Posted: Mon Apr 09, 2012 5:48 pm
Steve, I had typed a couple of responses to some comments here and then thought I'd have a look back through the HEDGEPIG build before posting to get a handle on some of your comments. Fantastic! Hadn't looked for quite some time and it truly has become quite an engineering marvel.
I now better appreciate some of your recent comment direction, I still think you're basing your comments on not accepting that everyone wants something different and not necessarily looking to drive your sort of terrain, but I get where you're coming from.
Would be nice if you could get a measure mid way of the wheel base from ground to underside of your chassis rail as a comparison. Would be interesting to know how it compares to an 80mm lifted Jimny.
Post Posted: Mon Apr 09, 2012 5:54 pm
tyre size is going to be an issue there =) not many jimnys on 35" krawlers! haha
Post Posted: Mon Apr 09, 2012 5:56 pm
The there's the width of the rims/tyres to compensate for any height.
And Jimnys aren't a ute. There's no real point.
Post Posted: Mon Apr 09, 2012 5:58 pm
:lol: I still can't see why everyone is getting there panties in a knot over 30MM, i mean it's 30MM FOR FUCKS SAKES!!!! :lol:
Post Posted: Mon Apr 09, 2012 5:59 pm
I had a great day out hard wheeling.
My CVs held up to some pretty hard pulls, my rear radius arm mount caught on a few rocks and I pinched a tyre.
And I was driving everything dan drove. Angle for angle. Line for line.
Next on my list is 3-link the front.
In reply to steve.
Thanks, stealth mods are awesome, my old lwb ran lifted TC, $4000 TBI/engine rebuild, Cressida PS, RUF, and when you stood back it looked like I had put a set of 235s on it and driven it to the bush for a picture.
But that's what I wanted, and that's what my Jim will be.
I know I said this before, but if someone was selling a streched tintop Sierra, with coils, AC, PS, injection, no rust, completely engineered, only thing it needed to be really really reliable was chromo's, wouldn't it sell for around 6-7K? If you were to build a Sierra to that point (not dodgy, reliable) it would cost you way more then that.
Mine was 5k, and all it needs is chromo's and I'll be able to wheel all day without a worry. The Jim driveline is strong except the CVs.
Post Posted: Mon Apr 09, 2012 6:25 pm
You'd hate to have me around then.... I get the shits when I put less flogged out leafs in the front of my LJ and it sits higher. Its took about 3 months of flogging the shit out of them to get them to the nice flat ride height they are now :) (and the car is most definitely the best it has ever been now). I will probably be pulling out the springs on the cars next incarnation, and resetting them to flat before I even drive it :) .
Clearance Hole Technology :P
Vehicle: 96 coily Awesome sticker Rust
Post Posted: Mon Apr 09, 2012 6:31 pm
drewmouli wrote:
pppfffffttttt horseeee poooooo pretty sure i have the most controversial daily driver ever. M18 with 40,000km put on it on a M13 ecu with no issues. 80mm lift with 31s, 22% reduction in high 30 in low, winch and bombed out to make your ears bleed. I do a minimum of 70kms a day for work no issues. you eastern states people are wanks. We hate dealing with you at work. You dont even know we have a different time zone over here.
Jeez bit harsh :oops:
We all might think that about them but we don't write it
I have issues
What are you looking at
Post Posted: Mon Apr 09, 2012 6:36 pm
if its only 30mm then why go from a 235/75r15 (28.8") to a 31" tyre - thats only 27mm taller too =)
my sierra is wider than it is taller, and by a fair bit... plus added unsprung weight making it far more stable than stock... the argument of 80mm spring lift gwagen is trying to make is that you're not adding as much width as you are height, so inevitably you'll end up with a less stable vehicle... running 80mm and 31's means you're about 5.7" (143.5mm) taller than stock =)
Post Posted: Mon Apr 09, 2012 7:00 pm
FKN LOL
Post Posted: Mon Apr 09, 2012 7:56 pm
FKN LOL
U'huh!
C'mon there's totally a point, strictly thinking COG. Rim offset aside because going wider is reasonably easy. Tyre height is also not what we are talking about here, topic being 80mm on a Jimny. What I'm interested to know is what is considered too much height and the chassis seems like a pretty obvious place to gauge this.
I'm guessing that wheel track aside, my Jim and Hedgepig will have their sprung mass a similar distance from terra firma.
Post Posted: Mon Apr 09, 2012 8:13 pm
sprung mass isnt totally relevant though, as unsprung mass (low down) is going to dramatically affect CG, and you can't set width aside because that also affects CG, and to say its easy to go wide isnt true either - theres limited rim choices to go wider, and the 12.5" wide krawlers alone are adding more width than the rims are. The height of the chassis has a bearing on CG, sure, but theres too many other factors to compare the 2 vehicles so basically.
Post Posted: Mon Apr 09, 2012 8:17 pm
13.5" Krawlers.
And yes. They're too different to compare that way.
Post Posted: Mon Apr 09, 2012 8:18 pm
I give up
Post Posted: Mon Apr 09, 2012 8:19 pm
I give up
Thats the spirit :wink:
awww don't give up, this is fun.
Post Posted: Mon Apr 09, 2012 8:26 pm
Waste of time. Back to boobs thread, always time well spent
Post Posted: Mon Apr 09, 2012 8:50 pm
aw.. :( it was bout to get fun
bottom line is... I like the look of a 75mm lift on a jimny, and its awesome to be able to buy it off the shelf and bolt it on.... and dnt really see all the drible for 1" so :thefinger:
hahahahha :P
:mrgreen:
:Helloo: <<< (can ge get this emoticon back please)
Vehicle: 02 GV SQ625 + 84 Sierra SJ410
Post Posted: Tue Apr 10, 2012 9:28 am
^ That's exactly why people should be able to lock their own threads on this forum. If you want to do a build thread and not have comments, you have no choice on this forum.
Post Posted: Tue Apr 10, 2012 9:56 am
He's just a dick.
Post Posted: Tue Apr 10, 2012 10:06 am
sounds like you need a myspace page :thefinger:
Post Posted: Tue Apr 10, 2012 10:16 am
Wish people would take there hand off there dick.
Mate thats abit rough
joel wrote:
your a fuck head, that is all.
Maaate thats abit rough
SierraDan wrote:
He's just a dick.
OMFG Maaaaate thats abit rough
It seems we have a New Jim battle. So instead of the Sierra vs Vitara, We have a new contender.
The Jim should be against the new GV moreon's!
This thread is just the same as pootrols vs cruisers vs rovers :roll: :deadhorse:
Post Posted: Tue Apr 10, 2012 10:33 am
plant a seed and watch it grow :D
Post Posted: Wed Apr 11, 2012 9:10 pm
How many that have bagged out Jimny's actually own 1 or have ever driven 1 in a tricky situation.
Untill u do u have no idea Wat there like. Just cause YOURS MATES BROTHERS UNCLES COUSIN LAYED HIS ON IT'S SIDE TRUING TO DRIVE OVER A FLEX RAMP doesn mean there unstable and shit with more then 50 mm lift.
dodgy brothers mechanical
Post Posted: Wed Apr 11, 2012 9:31 pm
:cry:
Post Posted: Wed Apr 11, 2012 10:04 pm
I'm sure the multitude of experienced wheelers on here have no idea at all..... :roll:
Post Posted: Wed Apr 11, 2012 10:22 pm
But every person drives differently. So there for u cant really post an opinion unless u have experienced it yr self.
Post Posted: Thu Apr 12, 2012 12:21 am
actually from this forum I only know of two AZ member who have rolled their jimnys.... Liz for something more like an accident, and hers was a stockie, and Bugsta... not remember if he had 80mm or 50 and BL... but his was more of a driving style and bad luck and wrong line... I was there for the last two flips and it wasnt the "30mm of DEATH!!!" who did it
Post Posted: Thu Apr 12, 2012 6:35 am
:rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
50mm + 30mm body lift + retarded driving style
Post Posted: Thu Apr 12, 2012 8:31 am
thats a bit of a flawed argument though really... look at the sierras that are being rolled (and how many of them there are) and what they're driving vs. far less jimnys with far less mods/tyres not driving as crazy tracks and not having as blasé drivers. if there were as many jimnys on 31" plus tyres with complete disregard for panel damage (like most of the sierra drivers on here) then i reckon the rollover rate on jimnys would be pretty similar to sierras =)
Users browsing this forum: Brenno and 416 guests
