It is currently Mon Nov 02, 2026 5:30 am
Post Posted: Wed May 02, 2012 10:07 pm
hi again mates. finally tracked down a transfer cars to replace my busted 6.5 geared one. have 31s on it that are close to real size. how craps it gunna be with my 1.3 big block engine in me sierra?
gotta do it though. wont be going up all the hills anymore for a while i guess. be able to do little red at glasshouse still with it? has a new standard clutch in it
Post Posted: Wed May 02, 2012 10:14 pm
This will most likely result in either:
a) running into the trees or banks or upside down due to the speed you have to tackle it at to avoid stalling
b) If not option a you will run outta clutch trying to tackle it sensibly.
Lil Foot!
Post Posted: Wed May 02, 2012 10:23 pm
ok betta not try it then. hope its still reasonable for smaller stuff just so i can get back out into the bush
Post Posted: Wed May 02, 2012 10:33 pm
I only recall little Red years back when Royce actually wheeled and had his sierra. Even then it was a mission and you could really see to big tired vehicles struggle with control on standard gearing. They were bouncing into things and stalling all other the place!
Entertaining to watch tho ;)
Lil Foot!
Post Posted: Wed May 02, 2012 10:39 pm
yer its pretty extreme. lol
Post Posted: Wed May 02, 2012 10:40 pm
x2. It's crap.
Vehicle: SJ80, SE416
Post Posted: Thu May 03, 2012 9:02 am
That would depend on how much clutch you want to burn - you may not have much clutch left by the time you get to the top...
31s are bad on standard gearing even with a 1.6...
Post Posted: Thu May 03, 2012 12:57 pm
It'll be exactly like this....
http://www.youtube.com/watch?v=XmgXZLxgX6c
or maybe a bit like this....
http://s121.photobucket.com/albums/o221 ... ter=videos
Post Posted: Thu May 03, 2012 1:06 pm
That's a pretty good example Jas. More speed!! :D
Lil Foot!
Post Posted: Thu May 03, 2012 1:07 pm
Yep... Standard transfers suck the dick.
Post Posted: Thu May 03, 2012 1:13 pm
Would be an educational video for the fella's who believe in lockers before gearing once over-tyred. Just imagine the ridiculous speed you would have been pulling due to the added traction of lockers.
Crazy! Btw how the hell did those cv's hold up!
Lil Foot!
Post Posted: Thu May 03, 2012 1:17 pm
They were fine that day but the next time I drove that track I did a RH.
Post Posted: Thu May 03, 2012 2:52 pm
looks pretty gay. atleast the car be useable again anyway
Post Posted: Thu May 03, 2012 4:43 pm
Not necessarily. You have to hit things with so much speed you don't have time to judge things that can happen.
You could end up on your roof ;)
Post Posted: Thu May 03, 2012 5:53 pm
That would be option b) Eddie! :D
Lil Foot!
Vehicle: 1985 Holden Drover
Post Posted: Thu May 03, 2012 7:40 pm
I know that for a fact! Armsup
1989 WT Sierra.
Post Posted: Thu May 03, 2012 7:49 pm
i had 29's in my first one...with gearing....ended up on 33s but gearing is where its at!
now on 33s and 6.5s and its too low...but anyway...
want33's ya made that look hard!haha
back in a built sierra!
Post Posted: Thu May 03, 2012 8:00 pm
Depends on what you drive. I don't think 33's and 6.5's is too low at all- I'd say it's spot on for mixed technical driving.
Steve
Post Posted: Thu May 03, 2012 8:05 pm
I had 32s and stockys for a while and it sucked donkey balls. i even had to get winched up a hill by a gutlux becuase my car physically couldnt turn the tyres! just embarrasing. mind you it was a friggen steep hill haha
I love lamp
Post Posted: Fri May 04, 2012 3:41 pm
215s OR 235s would be more usable with the standard gears...
Post Posted: Fri May 04, 2012 3:48 pm
225's even ;)
Post Posted: Fri May 04, 2012 5:36 pm
215s OR 235s would be more usable with the standard gears...[/quote]
Don't forget that 215's while not huge is about 2 inch's bigger than the stock rubber...
So like going to 31's on a Hilux, Rodeo, BT50
Post Posted: Fri May 04, 2012 5:59 pm
i had a swb wt and 30's I killed clutches trying to slow it down for control all the time.
Post Posted: Fri May 04, 2012 10:32 pm
30s sucked balls with no gearing and still is shit house with 3.9 diffs and a 1 liter case still not low
Enough for some hills great for big holes but
Post Posted: Fri May 04, 2012 10:37 pm
4.16 reduction gears aren't too bad.
Post Posted: Sat May 05, 2012 12:23 am
i dunno what reduction il go with next time. didnt mind it with the 6.5s. only drive glasshouse. like crawling up things with the twin lockers. used 1st doin little red. did all my steep ones in 1st. would probably go again with same gears. but havent sampled any others lol
i shud probably confirm they are 6.5s. they are super low though i know that much
Post Posted: Sat May 05, 2012 9:05 am
for 31s i only ever recomend 4.9s but thats just me
Users browsing this forum: No registered users and 102 guests
