It is currently Tue Sep 22, 2026 3:48 am
Post Posted: Tue May 08, 2012 12:37 am
hi guys. wat type do i use for the sierra and do you know the amounts to put in? thanks
Vehicle: 1985 Holden Drover
Post Posted: Tue May 08, 2012 12:44 am
Its all in the FSM mate.
1989 WT Sierra.
Post Posted: Tue May 08, 2012 12:48 am
Vehicle: SJ80, SE416
Post Posted: Tue May 08, 2012 11:53 am
Just go to Repco/Autobarn/Supercheap and check the catalogue in the isle where the gear oils are kept. If you use a good brand such as castrol then you won't go wrong.
From memory, gearbox and transfer combined require about 2.5 litres. Diffs (slightly different grade again) take about 1.5L each.
Post Posted: Fri May 11, 2012 9:21 pm
i have some oil at home here already i found. does anyone know if its 85-90 grade?
Post Posted: Fri May 11, 2012 9:31 pm
Post Posted: Fri May 11, 2012 10:11 pm
oh good work. its all there. i did see the link last time but didnt click it
ment to be 75w-85. do you think 85w-90 will work also? save me buying it wen i have a full 4 litres already
Post Posted: Fri May 11, 2012 10:53 pm
I don't think it would do any harm in the transfer especially in Qld.
I would stick with the recommended VMX80 or equivalent for the gearbox.
Post Posted: Fri May 11, 2012 11:50 pm
my stuff is actually 80w-90 i think if i remebmber correctly.
Users browsing this forum: No registered users and 178 guests
