It is currently Sun Aug 02, 2026 12:52 am
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
Vehicle: 2018 DMAX
Post Posted: Sun May 06, 2012 10:24 am
Have recently put a G16b in my tintop, but having issues getting it running.
Timing is correct, its getting spark and fuel. Not getting any error codes right now, was throwing a MAP code but that's been fixed(loose plug).
The most I can get from it is a few back fires here and there... I don't have any noid lights to check injector pulse, this is about the only thing I can think that may be a problem.
Any one have any idea what I could be missing? I'm about to start hitting things with a hammer.
Post Posted: Sun May 06, 2012 10:27 am
if it has a map I assume it a Baleno engine?
Vehicle: 2018 DMAX
Post Posted: Sun May 06, 2012 10:32 am
Yep, dizzy baleno.
Post Posted: Sun May 06, 2012 10:34 am
baleno dizzy model with vit cam/dizzy?
viewtopic.php?f=4&t=13496&start=420
Vehicle: 2018 DMAX
Post Posted: Sun May 06, 2012 10:38 am
That's the one..
Sorry, hungover.. Brains not working too good right now.. :-|
Vehicle: 2018 DMAX
Post Posted: Sun May 06, 2012 2:56 pm
Have done some more testing....
Cam position sensor is working
TPS is in range
O2 sensor is in range
Coolant temp sensor is in range
Intake temp sensor is working
Ground and active on the ECU are fine
Coil/Ignitor work fine, good spark...
Replaced the lead from the coil to dizzy to the correct one, I now get it to kick on turning the key but it will not continue running.. Does it every time I try to start it, if I keep cranking after the kick it does nothing.
Possibly injectors are doing there first pulse but not continuing to fire, which should indicate the ecu is unhappy.. Possibly missing an input, but everything has been tested and works....
Post Posted: Sun May 06, 2012 5:51 pm
The ECU plug sweet? Not dodgy like last time?
Lil Foot!
Vehicle: 2018 DMAX
Post Posted: Sun May 06, 2012 7:38 pm
Looks good to me dude. This one wasn't as molested as the last set up.
Post Posted: Sun May 06, 2012 7:49 pm
just stick your meter on volts and put a probe onto each wire in teh plug and crank, the meter will flash voltage on and off if there is injector trigger there
how did you set the cam and ignition timing? did you use the correct keyway position on the cam pulley?
Vehicle: 2018 DMAX
Post Posted: Sun May 06, 2012 8:21 pm
Cam timing was done as per the FSM, I used which ever keyway it suggested. I think it was E?
For ignition timing, No1 was set at TDC on the compression stroke. Dizzy was set to strike No1 slightly advanced.
My meter doesn't show anything, I doubt it has the refresh rate to capture an injector pulse.
Post Posted: Sun May 06, 2012 8:31 pm
All vac lines connected correctly, including brake booster?
SS
Post Posted: Sun May 06, 2012 8:37 pm
Ignitor body grounded? Mate had very similar problems till he grounded te Ignitor.
Post Posted: Mon May 07, 2012 8:57 am
Ah hah.... Try the dissy at No.4.
Post Posted: Mon May 07, 2012 9:01 am
the good old suzuki trap :lol:
Vehicle: 2018 DMAX
Post Posted: Mon May 07, 2012 11:31 am
Ignitor and vac lines are all good. Tried sticking the dizzy on cyl4 but no luck. If its on cyl 4 it looks 180 out to me?
First part of the vid was with the dizzy set to Cyl1, second half is it set to Cyl4
Post Posted: Mon May 07, 2012 11:47 am
squirt something flammable into the intake to see if it goes longer
if the pops in the video at the end were backfires in the intake then it was wrong then
Vehicle: 2018 DMAX
Post Posted: Mon May 07, 2012 12:14 pm
Sprayed some aero start down it but didn't really make a difference.
The back fires at the end sounded like they were out the intake..
Vehicle: 2018 DMAX
Post Posted: Mon May 07, 2012 1:33 pm
Just chucking ideas out there because nothing seems to be fixing this, if the head gasket or intake gasket was incorrectly made would it stop it running? Everything seemed fine when I fitted it but I may have missed something...
Post Posted: Mon May 07, 2012 4:10 pm
Put the dissy back in the way you had it to start with.
(Both front cam lobes 'on the rock', rotor pointing to No.1)
Then lift dissy enough to disengage the drive, turn engine over one full rev, put dissy back in.
Vehicle: 2018 DMAX
Post Posted: Mon May 07, 2012 8:43 pm
Yea no luck with that.
Post Posted: Mon May 07, 2012 9:10 pm
Have you got the starter motor signal wire (black with yellow) hooked to the ECU?
Post Posted: Mon May 07, 2012 10:32 pm
take a look at the trigger wheel in the original dizzy , im pretty sure you will find it has a "home signal" for the ecu . IE it has 4 evenly spaced teeth then a tooth next to a tooth ... so the ecu see's it as 1 .. 3 ... 4 ... 2 ... "home".
ive just recently modified a vitara dizzy to run this setup for a baleno .
let us know what you find..
Post Posted: Tue May 08, 2012 6:11 am
What he said ^
2000 Suzuki Vitara 1.6 8V
1986 Suzuki SJ413K
Vehicle: 2018 DMAX
Post Posted: Tue May 08, 2012 7:41 am
Thank you!!! Had a look and they're different. The vit unit doesn't have the extra tooth.
How hard was it to mod the vit unit to work?
Post Posted: Tue May 08, 2012 12:21 pm
I have special tooling to remove the pin in the sprocket/ dog drive . When i have it apart i also replace the internal oil seal , so for me its pretty easy...
Vehicle: 2018 DMAX
Post Posted: Tue May 08, 2012 6:32 pm
I pulled the Baleno unit apart easy enough... Wasn't game to try pull the vit unit apart. Is the tooling to pull it apart commercially available or is something you made?
Post Posted: Tue May 08, 2012 7:41 pm
Its stuff i made . if i remember i will take some pics of the jig i made tomorrow.
Vehicle: Suzuki Jimny 2009
Post Posted: Tue May 08, 2012 7:48 pm
I suppose you have checked that you have the firing order right? Sometimes the simple things are overlooked.
Post Posted: Tue May 08, 2012 8:04 pm
trust me on this , and also the OP has confirmed the differences in the dizzy . i have used this engine in so many applications including aircraft with aftermarket ecu.. thats how i knew about the extra tooth (which usually can be configured with aftermarket ecu). The factory ecu needs to see that home signal to know exactly what part of the cycle its at . its different with the wasted spark coil pack setup where it uses a cam and crank signal to determine what part of the cycle its at.
Vehicle: 2018 DMAX
Post Posted: Tue May 08, 2012 8:30 pm
The extra tooth should of been apparent to me after playing round with Baleno dizzy, I didn't even think to confirm the Vit unit was the same.
Makes me wonder how other people have done this in the past, there seems to be a few posts about people slapping the vit cam and dizzy on a Baleno and having it work fine.. Possibly later dizzy Balenos used a CAS. Mine had a sensor physically fitted to the motor with a compatible sump, but it was not in use.
losfer, some pictures would be great.
Users browsing this forum: No registered users and 1191 guests
