It is currently Mon Sep 21, 2026 12:39 pm
Vehicle: Suzuki sierra
Post Posted: Wed May 09, 2012 1:02 pm
With your front tailshaft that goes to your transfer case to your front diff.when I took it out does the spline suppose to just come out out the shaft
Post Posted: Wed May 09, 2012 1:05 pm
yes :mrgreen:
Post Posted: Wed May 09, 2012 1:06 pm
it has to go back together the same
Post Posted: Wed May 09, 2012 1:10 pm
So you just can't slide it back into place.
Post Posted: Wed May 09, 2012 1:13 pm
you can but i say it be unbalance
Post Posted: Wed May 09, 2012 1:16 pm
Ok thanks guys
Post Posted: Wed May 09, 2012 1:53 pm
Are all the sierras got the same front tailshaft
Post Posted: Wed May 09, 2012 1:58 pm
no. 1.0 have a solid shaft with 8mm bolt holes. 1.3 nt has a hollow shaft with 8mm bolt holes and 1.3 wt has hollow shaft with 10mm bolt holes.
coilys probably have shafts made out of cheese with paper clips to hold it together.
Post Posted: Wed May 09, 2012 2:00 pm
Does the 1986 have the same as the 1990 models
Post Posted: Wed May 09, 2012 2:02 pm
no
Post Posted: Wed May 09, 2012 2:13 pm
86 and 90 have the same shaft and unis, it's only the flanges that re different.
Post Posted: Wed May 09, 2012 2:15 pm
you cant un bolt a tailshaft from a 1990 sierra and bolt it into a 1986 sierra
Post Posted: Wed May 09, 2012 2:57 pm
If you want to replace the shaft cauyse you pulled it apart and now dont know what to do
look closely where the 2 bits slide together, any luck youll see apunch mark on both bits, lines these up and slide it together
Post Posted: Wed May 09, 2012 4:18 pm
I'm looking at a 1986 model and I wAnt the tailshaft to go on my 1990.
Post Posted: Wed May 09, 2012 4:22 pm
What's wrong with your one?
Post Posted: Wed May 09, 2012 4:30 pm
The spline is real slopping you can wiggles around when you shake the tailshaft
Post Posted: Wed May 09, 2012 4:56 pm
mine has been like that for years i just dont go over 50kph with the hubs locked :wink:
Post Posted: Wed May 09, 2012 5:16 pm
What about 4wding
Post Posted: Wed May 09, 2012 5:21 pm
Deego wrote:
What about 4wding
i dont drive fast in the bush.
Post Posted: Wed May 09, 2012 8:50 pm
grease it up, seems most people forget they need grease in em
Users browsing this forum: Google [Bot] and 120 guests
