It is currently Fri Sep 25, 2026 7:35 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
Post Posted: Mon Aug 27, 2012 8:14 pm
Post Posted: Mon Aug 27, 2012 8:20 pm
thanks ball.
extremely close but doable.
Post Posted: Mon Aug 27, 2012 8:21 pm
jonno_racing wrote:
thanks ball.
nope
those holes are only 13mm in diameter. By the time you put a chamfer on them for the nuts you will have 2 that will likely break through to the hole next to them.
Post Posted: Mon Aug 27, 2012 8:24 pm
ball wrote:
jonno_racing wrote:
thanks ball.
nope
how deep is a stock chamfer?
Post Posted: Mon Aug 27, 2012 8:27 pm
18mm chamfer is the green line. I would suspect the chamfer to be a bit bigger than what I have drawn
Post Posted: Mon Aug 27, 2012 8:29 pm
Weld the holes up properly and get your mate who's machining your gears to chuck the wheels in the mill and get it done properly.
Post Posted: Mon Aug 27, 2012 8:34 pm
dam that's close...
I will grab out the verniers out and have a proper measure at some stage.
60' is the angle of the taper if any one is wondering.
Post Posted: Tue Aug 28, 2012 9:03 pm
jonno_racing wrote:
wow that's pretty hektic, you would think they would take the valve out before even starting that kind of job?
Even thats not enough to be safe.
Users browsing this forum: No registered users and 137 guests
