It is currently Wed Nov 04, 2026 8:15 pm
Vehicle: Suzuki Grand Vitara
Post Posted: Mon Oct 29, 2012 7:18 pm
Will Jimny Rims fit a 1995 Vitara?
Post Posted: Mon Oct 29, 2012 7:36 pm
Yes, and will give a wider wheel track.
Not sure of what tyre size will work but I'm sure the Vit guys will chime in with an answer.
Post Posted: Wed Oct 31, 2012 10:19 pm
I carried one as a spare for a while when I first got the Vit, but don't remember what the offset was.
Bolt pattern and centre bore are fine.
Tyre wise (without having the offsets to compare) anything up to a 235/75/15 should be relatively painless with the normal aftermarket 30-40mm suspension lift.
Post Posted: Wed Oct 31, 2012 11:05 pm
Jim stock steelies are -10
Leaf Sierra stock steelies are -5
Vit rims have to be 0 or + something. More inset.
Post Posted: Wed Oct 31, 2012 11:12 pm
+25 for 15x5.5 vit stockies from memory
Post Posted: Thu Nov 01, 2012 6:42 am
I have always assumes they were the same :o
Post Posted: Thu Nov 01, 2012 7:25 am
Cheers,
I have a set of Jimny rims coming soon but thinking about fitting to my Sierrra now.
I have a set of 15x7 Sunraysia Wheel Pattern RIms fitted to my Vitara with road tyres.
The car has alway had a bit flip flop when driving along and I put it down to tyre height.
When I had the spare on the back of the car it used to wobble/spring on the mount when hitting bumps.
The new rims and muddies I brought has no wobble/spring. (using very technical words here)
The White Sunraysia rims have a larger offset compared to the Ranger ones I just brought.
So I am thinking the Sunraysia rims are the cause of the flip flop.
Will have to see how the Ranger rims drive.
Post Posted: Thu Nov 01, 2012 8:46 am
Yeah same until i looked at the rims compared to my sierra's. more dish. 8)
Post Posted: Thu Nov 01, 2012 8:57 am
Learn something new everyday :D I'll have to stop telling people they are the same :oops:
Post Posted: Thu Nov 01, 2012 10:29 am
This is for the WT with dimpled circles style. They look the same.
NT sierra with triangles may be different
Post Posted: Sun Nov 04, 2012 2:55 pm
Does anyone know what the Offset is for the Dynamic Black Steel Wheels?
There website doesn't say.
The Mullins Ranger White Steel Wheels I have are - Offset 10 Pos.
The Dynamic Wheels sit inside the guards compared the Mullins outside.
I am worried the Dynamic Wheels are not the correct/offset for my Vitara.
Post Posted: Sun Nov 04, 2012 3:35 pm
Define correct?
You're running the Calmini lift, aren't you? What size tyres? Body Lift?
If they are inside the guard, good.
If your tyres don't catch on the guards or firewall as they steer or as the suspension compresses, good.
If your tyres don't rub on the chassis at full lock, good.
If your wheelbearings don't die a horrible death every 5,000km, good.
If none of the above occurs, I'd say that's pretty much as correct as you can get.
If any of the above occurs (except maybe the bearings) there are easy fixes: Flares, guard or firewall chopping/hammering, adjusting steering stops.
If all the above occur you'd want to have a good reason for running the rims - or be able to blame it on the 32" tyres you're trying to stuff under there.
Post Posted: Sun Nov 04, 2012 4:20 pm
DarkHorse wrote:
Define correct? Pretty much as you listed below, I thought I might have to have a certain offset or else tyre/part damage.
You're running the Calmini lift, aren't you? Yes What size tyres? 30" Body Lift? No
If your tyres don't rub on the chassis at full lock, good. I test fitted the front and no problem, but not with flexing the vechicle.
I haven't test fitted the rear, I think on full flex they will scrub the inner body wheel arch as the old MTR's just touched on one side
If your wheelbearings don't die a horrible death every 5,000km, good. NO COMMENT
Here is a pic of the old MTR's and Mullins Wheels.
Post Posted: Sun Nov 04, 2012 5:05 pm
I *think* you'll be OK then... sounds like they're probably +25 or so. More + offset will help clear the arches with steering, but check the clearance on the chassis:
If it's just a corner of the tyre rubbing on the inner arch at the back you might get lucky, more + offset will bring the tyre closer but reduce the diameter of the tyre swing as it moves up.
Whack 'em on and see how ya go :lol:
Post Posted: Sun Nov 04, 2012 9:27 pm
I just checked my receipt from the tyre shop and it has +10 offset for the rims.
Also have emailed Dynamic to see what the ofset is.
Will have to fit the wheels and try it out next weekend.
Post Posted: Mon Nov 05, 2012 4:09 am
So the same as your white ones? Too easy?
Post Posted: Mon Nov 05, 2012 12:04 pm
No, just got the email back from Dynamic and they said the rims are -12.
Tyre place said NO they are not -12 you have +10.
Ok test fit this arvo.
Post Posted: Mon Nov 05, 2012 6:28 pm
Ok did a test fit and flex, it all clears at the moment.
Pics tomorrow.
Post Posted: Tue Nov 06, 2012 6:06 am
On another subject does anyone know whereto get Chrome mag wheel nuts cheap.
Suzuki 12x1.25
Everyone ask too much for them and the quality is crap as well.
Post Posted: Tue Nov 06, 2012 6:40 am
I got mine from StupidCheap, everywhere seemed to be much the same price, give or take, and at least they had 5 packs of four in stock at the time.
Vehicle: SJ80, SE416
Post Posted: Tue Nov 06, 2012 3:38 pm
Wreckers...
Post Posted: Tue Nov 06, 2012 8:13 pm
Reubs wrote:
Wreckers...
Went to one wreckers on the weekend and he said it wasn't worth his time selling me old wheel nuts.
Post Posted: Tue Nov 06, 2012 8:22 pm
does QLD have self serve wreckers?
Post Posted: Tue Nov 06, 2012 8:46 pm
I got a quote from Repco, and then bought them from Tempe Tyres for around half that.
Post Posted: Tue Nov 06, 2012 9:03 pm
Not any I know of or visit.
Post Posted: Tue Nov 06, 2012 9:10 pm
I might have to ring a few of the tyre shop.
Post Posted: Tue Nov 06, 2012 9:24 pm
Salisbury wrecking.
just pocket them.
Post Posted: Tue Nov 06, 2012 9:29 pm
Salisbury wrecking.
just pocket them.
Or throw them over the fence.
Post Posted: Sun Nov 11, 2012 6:21 pm
Fitted the Jimny rims to the Sierra, looks nice.
Post Posted: Thu Dec 06, 2012 10:12 pm
Here is how the BFGoodrich fit.
Anyone can see the offset is different.
Users browsing this forum: No registered users and 201 guests
