It is currently Fri Sep 18, 2026 10:38 pm
Post new topic Reply to topic  [ 65 posts ]  Go to page 1, 2, 3  Next
Vehicle: Suzuki jb43 jimny
Post Posted: Mon Nov 12, 2012 7:32 pm
Once again members of az I'm calling on your help, recently I noticed my thrust bearings gone, with this booked in to be replaced I'm looking at doing the clutch at the same time I'm just not sure what one to go for, heavy or just normal. Thanks for the help :peaceout:
Post Posted: Mon Nov 12, 2012 7:37 pm
Get normal.
Post Posted: Mon Nov 12, 2012 7:55 pm
Any reason
Post Posted: Mon Nov 12, 2012 7:56 pm
Wouldn't the heavy one be better for off road
Post Posted: Mon Nov 12, 2012 8:10 pm
Heavier will achieve nothing but less control off road
And a sore leg
Post Posted: Mon Nov 12, 2012 8:15 pm
And broken clutch cables
Post Posted: Mon Nov 12, 2012 8:16 pm
and cracked firewalls
Post Posted: Mon Nov 12, 2012 8:17 pm
Sounds like not heavy then
Post Posted: Mon Nov 12, 2012 8:18 pm
Thought it may work better but hence asking
Post Posted: Mon Nov 12, 2012 8:59 pm
Heavy clutches suck. I broke 3 cables in a weekend then removed the clutch and put a standard one back in
Post Posted: Mon Nov 12, 2012 9:06 pm
Alright then thank you : D ill keep the standard r replace if worn with a standard
Vehicle: Ford Maverick 4.2 Diesel
Post Posted: Mon Nov 12, 2012 9:09 pm
$110 for a brand new standard bud!!! comes with thrust
Post Posted: Mon Nov 12, 2012 9:50 pm
Where's that from mate
Post Posted: Mon Nov 12, 2012 9:58 pm
clutch ind.
Post Posted: Mon Nov 12, 2012 10:05 pm
Where they based mate is that trade price, about to google them
Post Posted: Mon Nov 12, 2012 10:10 pm
It is possible to get a heavier clutch with little difference in pedal difference. I purchased a standard EXEDY modified by NPC in Brisbane. They claim 40% extra clamp pressure for negligable extra pedal pressure, and I didn't notice it when I got it back on the road. Whereas, Exedy HD is 25% extra clamp with same pedal pressure increase.
I have ben extremely happy with mine. Handles the extra power well and does no smell nearly as much as the original.
Post Posted: Mon Nov 12, 2012 10:16 pm
So u belive a hd is a good investment, I thought it would as it should last and perform better under pressure and on climbs
Post Posted: Mon Nov 12, 2012 10:33 pm
Were going round in circles lol....go standard. You will thank everyone later. I have them at work!!!
Post Posted: Mon Nov 12, 2012 10:36 pm
That's cause I only wish to do it once.... Do it once do it well
Post Posted: Mon Nov 12, 2012 10:39 pm
You will get sick of the heavy pedal bud. Not as easy to control and maintain foot pressure when wheeling.
Post Posted: Mon Nov 12, 2012 10:40 pm
I can dump my clutch at 6000 rpm in 2 nd low while dragging my 1400kg boat off a beach and have zero clutch slip.
That is with 33 inch tyres and a stock clutch. I don't understand why people think hd clutches are the go. Get ya gearing right and ya will have no issues.
Post Posted: Mon Nov 12, 2012 10:43 pm
Ok, well I'm glad that's sorted now for the work part : P should be good once it no longer sounds like I have a cat in my tranny
Post Posted: Mon Nov 12, 2012 10:50 pm
i don't have a clutch :?
say :no: to clutches Armsup
Vehicle: 2003 V6 Grand Vitara (SQ625)
Post Posted: Tue Nov 13, 2012 3:24 am
If i said no to a clutch... It wouldn't run very well - Or not at all :(
http://www.auszookers.com/forum/viewtopic.php?t=36934
Post Posted: Tue Nov 13, 2012 5:40 am
Haha I have thought about a auto Atari but I don't think I'd ever let myself love my manuals : P
Post Posted: Tue Nov 13, 2012 5:45 am
A heavy duty clutch won't last any longer than a standard there's still the same amount of friction material. You just have more clamping force which typically means more pedal pressure, more strain on clutch cable and firewall, more driveline shock when you dump the clutch.
G13 only produces 100nm, many use the standard clutch with a g16 so just buy standard. They are cheap and easy to replace in a Sierra anyway.
Post Posted: Tue Nov 13, 2012 6:24 am
You gain that extra pressure with no increase in leg effort by having a longer pedal throw, which on a Vitara is a right pain in the ass cause there isnt enough already so the clutch doesn't fully release and kills cables
Post Posted: Tue Nov 13, 2012 7:25 am
Yeah but his isn't a Daily Driver (DD), it's really only a Once Every Few Months Driver (OEFMD) so longer pedal throw wouldn't bug the bugsta.
Post Posted: Tue Nov 13, 2012 7:44 am
Pun intended
Users browsing this forum: No registered users and 207 guests
