It is currently Sat Sep 26, 2026 7:11 am
Vehicle: 1985 lwb sierra UTE
Post Posted: Thu Nov 01, 2012 6:56 pm
Any tricks to installing king pins and shims?
Post Posted: Thu Nov 01, 2012 7:24 pm
12mm socket.
Chisel/Screwdriver/Punch
Hammer.
Post Posted: Thu Nov 01, 2012 8:03 pm
Fish scales
Post Posted: Thu Nov 01, 2012 8:35 pm
Lol wt?
I got them apart fine and will be able to put it all back together. but I noticed they were shimmed so I'm trying to work why they were shimmed or are they all shimmed?
Vehicle: Drover pickup turk
Post Posted: Thu Nov 01, 2012 8:40 pm
There needs to be a certain 'preload' on the bearings, The shims help set the correct setting.
The fish scales will give you the reading. Have a read through the FSM, Very clear.
I like the tuna here
Post Posted: Thu Nov 01, 2012 9:06 pm
I should have done that first (read theFSM) { thanks guys)
Post Posted: Fri Nov 16, 2012 7:14 am
I,ve had fitter play with mine.No good.
What's FSM ?
Thanks.
Bye
Post Posted: Fri Nov 16, 2012 7:35 am
cairns27 wrote:
What's FSM ?
Bye
Fucking service manual
Bye
Post Posted: Fri Nov 16, 2012 7:48 am
What's FSM ?
Thanks.
Bye
There is your problem. Fitters replace components and mechanics rebuild components. If you are fixing bearings fitter style then ya need to buy a new assembled diff assembly and replace the lot. Mechanics can replace indervidual bearings. :wink:
Post Posted: Sat Nov 17, 2012 9:25 am
What's FSM ?
Thanks.
Bye
You really need to define who you are talking about shep. A fitter is in maintenance and manufacturing, building and machining whatever is needed.
A bullbar fitter is not.
Users browsing this forum: Google [Bot] and 24 guests
