Vehicle: 96 Sierra Tintop swb nt coily
Posted: Fri Dec 14, 2012 6:33 am
Im putting a g16a into my sierra but the carby is missing a few linkages and hoses. Is it possible to put the carby of my g13b as its complete and not long had an overhaul.
Joined: Mon May 16, 2011 7:03 pm Posts: 686 Location: Brinkworth, England
Posted: Sat Dec 15, 2012 8:03 am
I ran a g13 carb on the 1.6 with the SJ manifold. I opened out the intake ports on the manifold and trimmed it to fit around the 1.6 pump. It works but its not great and it won't let you get full power from the 1.6.
Posted: Thu Dec 20, 2012 4:23 pm
Howd you go with plumbing up the charade carby though. Im ready to burn this thing trying to fgure out vacuum n fuel lines for the g13 carby let alone a daihatsu one...
It all plumbs up with all the same plugs vacuum lines etc as the factory G13a the only things that needs done is swap over the linkage for the accelerator cable and cut the end of the choke cable. and it uses shorter bolts
Users browsing this forum: No registered users and 216 guests
