It is currently Sun Oct 25, 2026 8:39 pm
Vehicle: 96 Sierra Tintop swb nt coily
Post Posted: Fri Dec 14, 2012 6:33 am
Im putting a g16a into my sierra but the carby is missing a few linkages and hoses. Is it possible to put the carby of my g13b as its complete and not long had an overhaul.
Post Posted: Fri Dec 14, 2012 6:42 am
It would be easier to buy g16 carb from a wrecker and just bolt it on. You could sell your g13 carb to off set the cost of the knew one.
Post Posted: Fri Dec 14, 2012 6:47 am
Yeh thought that but having the motor out means no transport n closest wrecker with one 40 minutes away n i need the little bastard running asap.
Post Posted: Sat Dec 15, 2012 8:03 am
I ran a g13 carb on the 1.6 with the SJ manifold. I opened out the intake ports on the manifold and trimmed it to fit around the 1.6 pump. It works but its not great and it won't let you get full power from the 1.6.
Post Posted: Tue Dec 18, 2012 6:43 pm
Spoke to shep and he said he bolted one straight on his 1600 no problems with good output
Vehicle: 86 SJ413 31's 1.6
Post Posted: Wed Dec 19, 2012 1:52 pm
I put the 1300 manifold on my injected 8V G16a in my SJ413. And im using a 3 cylinder daihatsu charade Carb with no problems
Post Posted: Thu Dec 20, 2012 4:23 pm
Howd you go with plumbing up the charade carby though. Im ready to burn this thing trying to fgure out vacuum n fuel lines for the g13 carby let alone a daihatsu one...
Post Posted: Thu Dec 20, 2012 5:33 pm
I was having problems with my factory carb and i found this
http://www2.izook.com/?page_id=210
It all plumbs up with all the same plugs vacuum lines etc as the factory G13a the only things that needs done is swap over the linkage for the accelerator cable and cut the end of the choke cable. and it uses shorter bolts
Users browsing this forum: No registered users and 187 guests
