| Author |
Message |
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Sun Jun 21, 2009 2:31 pm |
How much does a stock 1.3 WT LWB weigh?
I don't have ready access to a weigh bridge and I want to try my G-tech performance meter out..
It is an accelerometer that mounts to windscreen and tells you:
0-60m/h
1/4 mile time and speed
Cornering G's
60-0 braking distance
Horsepower..
All you need to do is tell it how much the car weighs and then go testing.
I want to compare old 1.3 to new 1.3/1.6 hybrid I've put together.
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Sun Jun 21, 2009 2:37 pm |
my stock hard top was 1065kg =/- 50kg
lump_a_charcoal
Joined: Wed Feb 28, 2007 10:30 pm Posts: 4454 Location: Botany, NSW
Vehicle: MY2019 Jimny
 Posted: Sun Jun 21, 2009 2:54 pm |
Rego papers will tell you...
want33s
 Posted: Sun Jun 21, 2009 3:06 pm |
lump_a_charcoal wrote: Rego papers will tell you...
Not in Qld.. It's only an estimate.
11_evl
Joined: Tue Apr 10, 2007 11:30 pm Posts: 846 Location: logan reserve, Brisb
 Posted: Sun Jun 21, 2009 3:21 pm |
just put in a common weight and use that on the other setup
_________________ 92 sierra, 40" treps, full hydro, F&R steer, 106"W
want33s
 Posted: Sun Jun 21, 2009 4:01 pm |
11_evl wrote: just put in a common weight and use that on the other setup
Yeah I thought about that but want it as realistic as possible...
I guess 1250Kg will do
ca18zook
Joined: Sat Jan 19, 2008 10:30 pm Posts: 156 Location: Ipswich
 Posted: Sun Jun 21, 2009 5:18 pm |
my lwb weight was 1200kg with 2 people in it and its a ute. But it has a ca18 in it and had a small amount of rubbish on the back
Trent
_________________ Drive it like u stole it!!!
Cade
Joined: Mon Sep 29, 2008 11:30 pm Posts: 317 Location: Perth
 Posted: Sun Jun 21, 2009 6:13 pm |
i did not think they show 3 digits, how will you get the 1/4 mile time
Santos
Joined: Tue Jun 09, 2009 11:30 pm Posts: 1009 Location: Sydney -ish
Vehicle: 92 Suzuki Sierra
 Posted: Sun Jun 21, 2009 6:56 pm |
i went with 1150 with a swb, i figured i'd go a little heavier rather than lighter
_________________ -Santos
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Sun Jun 21, 2009 7:19 pm |
want33s wrote: How much does a stock 1.3 WT LWB weigh? I don't have ready access to a weigh bridge and I want to try my G-tech performance meter out.. It is an accelerometer that mounts to windscreen and tells you: 0-60m/h 1/4 mile time and speed Cornering G's 60-0 braking distance Horsepower.. All you need to do is tell it how much the car weighs and then go testing. I want to compare old 1.3 to new 1.3/1.6 hybrid I've put together.
Hey Jas i'll get in before TZAR or Royce does and give you the data:
0-60m/h = a long time
1/4 mile time and speed = a long time at a slow pace
Cornering G's = very low due to incredibly slow speed and the fact the vehicle leans into the corner to allieviate the G force.
60-0 braking distance = a long way
Horsepower = just a little less than a shetland pony with swine flu
want33s
 Posted: Sun Jun 21, 2009 9:45 pm |
2stroker wrote: Hey Jas i'll get in before TZAR or Royce does and give you the data: 0-60m/h = a long time 1/4 mile time and speed = a long time at a slow pace Cornering G's = very low due to incredibly slow speed and the fact the vehicle leans into the corner to allieviate the G force. 60-0 braking distance = a long way Horsepower = just a little less than a shetland pony with swine flu
rofl... yeah I realise its no F1 car but I want to comparee old motor to new... just so I can justify $800 to the missus.
shep
 Posted: Sun Jun 21, 2009 10:33 pm |
want33s wrote: 2stroker wrote: Hey Jas i'll get in before TZAR or Royce does and give you the data: 0-60m/h = a long time 1/4 mile time and speed = a long time at a slow pace Cornering G's = very low due to incredibly slow speed and the fact the vehicle leans into the corner to allieviate the G force. 60-0 braking distance = a long way Horsepower = just a little less than a shetland pony with swine flu
just do what i do and make stuff up
Santos
 Posted: Mon Jun 22, 2009 1:09 am |
what are the details on the hybrd?
i get around average 37hp on the gtech with a stock motor, but i may have to re-look at my launches cause i got 64hp by pretty much jumping straight to 4th from 2nd and flat footing it all the way to 100km (the first 20m readings are not used)
going to recalibrate the tacho and the sensor
(i got the RR)
TZAR
Joined: Tue Aug 01, 2006 11:30 pm Posts: 3461 Location: licking some windows
Vehicle: LJ20 LJ50
 Posted: Mon Jun 22, 2009 1:01 pm |
according to the suzuki owners manual
SJ413K- Drop side ute 890kg
GVM Gross vehicle mass = 1390kg
SJ413W long body
SJ413W Long body 900 kg for 2 seater
SJ413W Long body 910 kg for 4 seater
SJ413W Long body 910 kg for 2 seater with 15" wheels
SJ413W Long body 920 kg for 4 seater with 15" wheels
GVM Gross vehicle mass = 1370kg
and for the standard versions
SJ413 half metal door soft top version/SJ413Q soft top
850 kg for 2 seater
860 kg for 4 seater
860 kg for 2 seater with 15" wheels
870 kg for 4 seater with 15" wheels
GVM Gross vehicle mass = 1320kg
SJ413V
870 kg for 2 seater with 15" wheels
880 kg for 4 seater with 15" wheels
GVM Gross vehicle mass = 1340kg
_________________ Camels have nice toes
want33s
 Posted: Mon Jun 22, 2009 2:32 pm |
Cade wrote: i did not think they show 3 digits, how will you get the 1/4 mile time  I haven't used it yet but in the instructions it has a 4 digit display for time.. EG: 22.18 Santos wrote: what are the details on the hybrd?
My G-tech is a superceded model.
16V 1.6 bottom end (STD bore.. new rings and bearings)
8V 1.3 head.
Extractors and 2" system.
1.6 IMPORT TBI.
Thanks for the weight table TZAR.
Ridge
Joined: Tue Jun 16, 2009 11:30 pm Posts: 942 Location: Brisbane
 Posted: Mon Jun 22, 2009 9:17 pm |
twitchy
Joined: Fri Jul 25, 2008 11:30 pm Posts: 1086 Location: Lightning Ridge
Vehicle: 1999 Jimny
 Posted: Tue Jun 23, 2009 1:46 am |
Santos
 Posted: Tue Jun 23, 2009 1:47 am |
yah i had one of those older ones, from memory they only have one axs. ut they definately do 3 digit weights
let u know how you go
