It is currently Thu Oct 01, 2026 6:37 am
Post Posted: Sun Jun 21, 2009 2:31 pm
How much does a stock 1.3 WT LWB weigh?
I don't have ready access to a weigh bridge and I want to try my G-tech performance meter out..
It is an accelerometer that mounts to windscreen and tells you:
0-60m/h
1/4 mile time and speed
Cornering G's
60-0 braking distance
Horsepower..
All you need to do is tell it how much the car weighs and then go testing.
I want to compare old 1.3 to new 1.3/1.6 hybrid I've put together.
Post Posted: Sun Jun 21, 2009 2:37 pm
my stock hard top was 1065kg =/- 50kg
Vehicle: MY2019 Jimny
Post Posted: Sun Jun 21, 2009 2:54 pm
Rego papers will tell you...
Post Posted: Sun Jun 21, 2009 3:06 pm
Not in Qld.. It's only an estimate.
Post Posted: Sun Jun 21, 2009 3:21 pm
just put in a common weight and use that on the other setup
Post Posted: Sun Jun 21, 2009 4:01 pm
Yeah I thought about that but want it as realistic as possible...
I guess 1250Kg will do
Post Posted: Sun Jun 21, 2009 5:18 pm
my lwb weight was 1200kg with 2 people in it and its a ute. But it has a ca18 in it and had a small amount of rubbish on the back
Trent
Drive it like u stole it!!!
Post Posted: Sun Jun 21, 2009 6:13 pm
i did not think they show 3 digits, how will you get the 1/4 mile time :)
Vehicle: 92 Suzuki Sierra
Post Posted: Sun Jun 21, 2009 6:56 pm
i went with 1150 with a swb, i figured i'd go a little heavier rather than lighter
-Santos
Post Posted: Sun Jun 21, 2009 7:19 pm
0-60m/h
Cornering G's
Horsepower..
Hey Jas i'll get in before TZAR or Royce does and give you the data:
0-60m/h = a long time
1/4 mile time and speed = a long time at a slow pace
Cornering G's = very low due to incredibly slow speed and the fact the vehicle leans into the corner to allieviate the G force.
60-0 braking distance = a long way
Horsepower = just a little less than a shetland pony with swine flu
Post Posted: Sun Jun 21, 2009 9:45 pm
rofl... yeah I realise its no F1 car but I want to comparee old motor to new... just so I can justify $800 to the missus.
Post Posted: Sun Jun 21, 2009 10:33 pm
just do what i do and make stuff up :lol:
Post Posted: Mon Jun 22, 2009 1:09 am
what are the details on the hybrd?
i get around average 37hp on the gtech with a stock motor, but i may have to re-look at my launches cause i got 64hp by pretty much jumping straight to 4th from 2nd and flat footing it all the way to 100km (the first 20m readings are not used)
going to recalibrate the tacho and the sensor
(i got the RR)
-Santos
Vehicle: LJ20 LJ50
Post Posted: Mon Jun 22, 2009 1:01 pm
according to the suzuki owners manual
SJ413K- Drop side ute 890kg
GVM Gross vehicle mass = 1390kg
SJ413W long body
SJ413W Long body 900 kg for 2 seater
SJ413W Long body 910 kg for 4 seater
SJ413W Long body 910 kg for 2 seater with 15" wheels
SJ413W Long body 920 kg for 4 seater with 15" wheels
GVM Gross vehicle mass = 1370kg
and for the standard versions
SJ413 half metal door soft top version/SJ413Q soft top
850 kg for 2 seater
860 kg for 4 seater
860 kg for 2 seater with 15" wheels
870 kg for 4 seater with 15" wheels
GVM Gross vehicle mass = 1320kg
SJ413V
870 kg for 2 seater with 15" wheels
880 kg for 4 seater with 15" wheels
GVM Gross vehicle mass = 1340kg
Camels have nice toes
Post Posted: Mon Jun 22, 2009 2:32 pm
I haven't used it yet but in the instructions it has a 4 digit display for time.. EG: 22.18
My G-tech is a superceded model.
16V 1.6 bottom end (STD bore.. new rings and bearings)
8V 1.3 head.
Extractors and 2" system.
1.6 IMPORT TBI.
Thanks for the weight table TZAR. :wink:
Post Posted: Mon Jun 22, 2009 9:17 pm
check out this site
http://www.redbook.com.au/
you will find everything there
Vehicle: 1999 Jimny
Post Posted: Tue Jun 23, 2009 1:46 am
935kg according to this
http://www.4x4.in.th/specification.html
Post Posted: Tue Jun 23, 2009 1:47 am
yah i had one of those older ones, from memory they only have one axs. ut they definately do 3 digit weights
let u know how you go :)
Users browsing this forum: No registered users and 126 guests
