It is currently Sat Oct 24, 2026 7:37 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
Post Posted: Thu May 16, 2013 8:19 am
Richy my 1ltr has more diff clearance front and rear with 32s@7psi than my mates 80series with 35s @30psi
Post Posted: Thu May 16, 2013 8:54 am
tanshi wrote:
my SIerra/LJ diffs have well over 300mm of diff clearance after shaving
a 1.3 pumpkin can be shaved more than 20mm
I shaved 26mm out of my 1.3 Using 5mm plate, possible to get a bit more.. but depends how close you want to go or how little material
I shaved 26mm out of my vit rear diff. I used a junk GV centre (its a bit bigger) so its possible to get a bit more.
In the jig, my sierra front has 10mm more clearance than the vit rear.
BTW fellas
It was a grave dig, to provide info for people, as apposed to rumours of this on 31s equals that on 35s.
Measuring the axles and centres etc is a bit better than comparing tyre sizes and clearance, because as we all know tyre sizes are a bit random.
Post Posted: Thu May 16, 2013 9:05 am
Youd be better off measuring the housings mate.
That 9.5" vs Jimny comparo is pretty vague as the housings are all made differently. Axle centreline to bottom of the housing is more realistic. Even axle tube diameter is important in this topic.
But again.. Just drive it. The 5mm varations between measurements doesnt matter.
Post Posted: Thu May 16, 2013 6:35 pm
How much did u get off the bottem of ur vit rear dan
I need to do mine oneday
How hard was it to shorten
Thinking of shortening my gv to vit with to help with the shaft angle with the duall cases
Users browsing this forum: Google [Bot] and 137 guests
