It is currently Sun Nov 01, 2026 12:31 pm
Vehicle: 2004 Jimny 1.6
Post Posted: Wed Jun 19, 2013 7:12 pm
I'm looking to begin squezing some more power out of my Jimny G16B,
Figured I would start with some extractors and then move to an aftermarket ecu, probs haltec.
Who has extractors on their motor? Did It make much difference? I have always found extractors to be a gamble on the many cars I have owned with a little bit more power to them making a massive difference.
Thanks all
Post Posted: Wed Jun 19, 2013 7:19 pm
I have extractors on my G16B but I never drove it with a stock manifold.
Do you have a Jimny manifold or a vitara manifold? I can't comment on the jimny manifold, but the vitara manifold isn't actually all that badly designed, except that it falls apart.
Post Posted: Wed Jun 19, 2013 7:21 pm
I still have the Jimny manifold on my motor, as far as I can tell the heads are exactly the same on the g16b and the g13bb, correct me if I'm wrong.
Probs same exhaust manifold. G13bb exhaust might be a bit more closer to the block? Due to room issues??
Post Posted: Wed Jun 19, 2013 7:23 pm
From memory, the jimny and vitara manifold are very different.
Have a look in my build thread - I have detailed pictures of the stock (broken) vitara manifold and engine pipes. They are a kind of tri-y design, unlike the jimny.
Post Posted: Wed Jun 19, 2013 7:24 pm
Ahh I see, still curious about power gains though
Post Posted: Wed Jun 19, 2013 9:14 pm
There is little point moving to an aftermarket EMS without any internal modifications ... eg high compression, big cams .. If you have a std engine, then your are best off with the std ecu by far...
If you want to squeeze a few more hp then try larger cams, maybe even up the compression ratio by either skimming the block and using a thin msl head gasket. If you up the injectors, remove the AFM and put on a pod type filter with a free flowing exhaust, then a properly tuned ems may give you a few more ponys ... The G16B is just not designed for high RPM, High HP ... so if you are able to extract an additional 10KW then you are doing well ....
you could always strap on a Rotrex ....
Post Posted: Thu Jun 20, 2013 1:59 am
Thanks for the reply, but upping up injectors, or raising my compression, or a diff cam won't wake any improvement unless I change my engine management. For obvious reasons. Like I said before extractors make a small or decent improvement depending on the engine. I'm well aware how to get power from a motor, I own a 1995 Mazda Astina BA 1.8 ltr that blows 186kw atw that I built. My question was: who has fitted extractors to a G16B and what diff did I make to power.
I'm running a g13bb ecu anyway so it's the wrong computer for the motor to begin with, hence an after market upgrade in the future. I appreciate suggestions on building a motor but I just want a quick basic answer. Cheers
Post Posted: Thu Jun 20, 2013 4:56 am
Extractors will make the exhaust note a bit crisper but there will be no noticeable power or economy improvements unless you run it on a dyno.
Post Posted: Thu Jun 20, 2013 6:27 am
Im running extractors - no difference ... If you get an after market EMS - Don't get a Wolf! - I'm running a wolf in my MR2 and it's a bugger to tune very few people can tune them .. (have a look at Dec12 Fast Fours and Rotaries, my car is pushing 400 HP from a 1.6) Haltech would be a good choice - plenty of good tuners out there ...
Post Posted: Thu Jun 20, 2013 9:09 am
I got extractors no difference but my standard manifold was cracked that's why I changed.
Vehicle: 85 ' Drover
Post Posted: Thu Jun 20, 2013 9:41 am
Did you change the rest of your exhuast though?
Extractors on a restrictive exhaust, is still a restrictive exhaust.
Post Posted: Thu Jun 20, 2013 11:50 am
yes 2" system went in with it
Vehicle: 1995 Vitara, SWB
Post Posted: Thu Jun 20, 2013 12:22 pm
I will watch this with interest.
I'm suspecting that I might also have a cracked manifold on my G16B, and may need to go down the extractor road.
What inspection process is involved, and are the cracks easy to pick up with just a visual inspection.
I don't seem to have any engine symptoms at this point, just a very different exhaust noise from up front under hard acceleration.
Thanks in anticipation.
Post Posted: Thu Jun 20, 2013 5:10 pm
YES 2" system with high flow cat.
Post Posted: Thu Jun 20, 2013 5:14 pm
What inspection process is involved, and are the cracks easy to pick up with just a visual inspection..
Usually you will hear the problem before you see it.
A visual inspection is easy enough if you remove the heat shield.
Post Posted: Thu Jun 20, 2013 8:02 pm
Thanks for the info want33s.
I will remove the heat shield and have a look.
Might get someone to rev it up while I'm checking to narrow down where the problem is.
Kev.
Post Posted: Thu Jun 20, 2013 9:22 pm
my old vit had extractors into 2 inch pipe, standard cat and huge muffler when i got it
muffler copped a few big rocks so got the giant muff trimmed and replaced with a 'sports' single chamber muff
as i drove up the road it felt like it revved alot easier and pulled better from 3k onwards, also noticed a small improvement in efficiency
if you really wanna make some power from your exhaust manifold put one of them magic snails in
Post Posted: Fri Jun 21, 2013 4:51 pm
What the hell is a magic snail, one of those giant Milo tins ?
Post Posted: Fri Jun 21, 2013 4:58 pm
turobcharger
Post Posted: Fri Jun 21, 2013 5:06 pm
:rofl:
Post Posted: Fri Jun 21, 2013 5:21 pm
DOH, I have always known them as a hair dryer.
Ya gotta admit, some of the giant milo tins must make a lot of power hey, 1" pipe leading in, 6" going out, broom.
Post Posted: Sun Jun 23, 2013 5:08 pm
The manifold cracks I've seen haven't necessarily lead to noticeable exhaust leak or noise. There's also a gasket between the cast manifold and the two down pipes that may have failed - IMHO that would be more likely to create an audible leak than a cracked manifold.
Post Posted: Sun Jun 23, 2013 6:32 pm
Thanks Steve, I will also check this when I do the visual.
If the gaskets are buggered, should i just go down the extractor road or stick with the stock manifold which will probably fall apart anyway. :( :(
Extractors probably makes more sense I reckon. Armsup
Kev.
Post Posted: Sun Jun 23, 2013 6:55 pm
I'd be surprised if the manifold isn't cracked, it just might not be the source of the noise.
I'd agree, I'd go to extractors rather than trying to sort out the stock manifold.
Post Posted: Sun Jun 23, 2013 7:03 pm
My next job is now organized.
Extractors for the zook. Armsup Armsup Armsup and probably a new exhaust.
Kev.
Post Posted: Sun Jun 23, 2013 11:20 pm
I haven't got an aftermarket EMS but I have been intercepting and tweaking the MAF (early cone type) signal to the stock ECU. The gains in low-speed drivability were quite noticeable by richening up the mixture slightly. Idle quality also significantly improved.
Even though they may not be much max HP gain I've always wondered how much more area under the torque curve could be achieved over stock with an aftermarket EMS.
Users browsing this forum: No registered users and 87 guests
