It is currently Fri Jul 31, 2026 12:02 pm
Vehicle: 91 sierra, g16b,lift,30's
Post Posted: Mon Jun 24, 2013 6:48 pm
My sierra wipers don't work. I brought a replacement motor from suziauto today and plugged it in and the motor doesn't work. I dare say there must be a fault in the wiring somewhere? Is there a way to test this?
My 2nd question can I rig up a hotwired switch! Just a switch that has 12v to it then that goes to the motor and all I do is push once bam wipers work lol????
Online
Post Posted: Mon Jun 24, 2013 7:12 pm
Yep, you'l miss intermittent though.
Vehicle: Daisy
Post Posted: Mon Jun 24, 2013 7:13 pm
You should be able to, after all, afaik the wiper motor just spins around and around and that is what moves the linkages back and forth. You will want to work out how they do the different speeds though, whether it's just from the switch i.e. there is control gear in the wiring rather than different windings in the motor. I'd imaging like a ceiling fan, the control for speed should all be done at the switch/wiring harness and the motor is just a plain old dc motor.
Post Posted: Mon Jun 24, 2013 7:23 pm
I've been driving with rainex windscreen since I got the zook back on the road lol. If I get the top speed ill be happy. Can someone point me in direction of what colour wires are what?
Online
Post Posted: Mon Jun 24, 2013 7:32 pm
This should help.
Post Posted: Mon Jun 24, 2013 7:46 pm
Is it possible to get like a 2speed switch? Push once then push twice type of thing??
Post Posted: Mon Jun 24, 2013 7:55 pm
Volume dial ?
Post Posted: Mon Jun 24, 2013 8:10 pm
http://db.hella.com.au/cgi-bin/catalogu ... lmaint=365
http://www.partsforhotrods.com.au/store ... id139.html
Either one of these would work?
Post Posted: Tue Jul 09, 2013 7:44 pm
Ok so before wiring up a switch I thought I'd try a replacement combination switch (wiper and indicator stalk assembly). I hooked this up and still no luck. Does the wiper motor earth through its body and into one of the mounting screws? I only plugged in the wiper motor, I haven't mounted it yet. What's my next test I can do?
Post Posted: Tue Jul 09, 2013 11:15 pm
The wiper motor body needs to be connected to ground for it to work. Once you have the body grounded you can simply test the motor itself be applying 12V to either the blue or blue/red wires.
Post Posted: Wed Jul 10, 2013 8:38 am
Thanks dan!!
Users browsing this forum: No registered users and 295 guests
