It is currently Thu Jun 18, 2026 6:26 am
Vehicle: 1995 2.0V6 Vitara LWB
Post Posted: Thu Jun 27, 2013 8:04 pm
hey guys i tried a search but it wasn't much help
iv ordered some 30mm springs and 30mm spacers and i have never used spacers before.
1: do they go on top of the spring or underneath or does it not really matter either way?
2: how are they held in place or do they just sit there?
3: any recommendation for bump stop extensions for 29.5" tyre with 60mm lift i was going to start of with a 30mm extension and go from there...?
4: some pics are always nice.
5: the springs i ordered are "king" and i have been anxiously waiting for them to arrive since i ordered them on friday and they have only been sent Today!! how fkn slack the spacers were sent on Monday not bloody happy
Post Posted: Thu Jun 27, 2013 8:15 pm
In a Vitara coil spacers go on top of springs, they can't fall out from the top.
30mm spacer would be best with 30mm bump stop extension,
so coil operates in same range as designed, in my opinion.
On front that is only a 15mm spacer and bump stop because the spring is inboard.
Post Posted: Thu Jun 27, 2013 8:25 pm
cheers mate.
ill remember that on top so they just sit there?
i wasn't planning to do the extension on the front as either my springs are too stiff or the sway bar is the front end does not go near touching the guard even standard height with 29.5" tyres :blink:
i dont know maybe because i couldn't flex it properly before with the rear end scrubbing and once i fix that and the rear end reaches full flex the front will start to move?
i figured match the extension to the spacer to at least prevent over compression of the spring as it would cause sag over time the fact that u agreed gimes me some confidence in this if it still scrubs ill have to add more.
wow looks like u have about 2.5" spacers
Post Posted: Thu Jun 27, 2013 8:31 pm
Sway bar will prevent compression on front, yes.
It may soften up, see how it goes.
The spacer is a tight fit over the protrusion, so it will just sit there.
I like to keep travel close to the engineers design, either Suzukis,
or in my case Old Man Emu, its just moved.
Vehicle: 93 Vitara -itty bitty lift
Post Posted: Thu Jun 27, 2013 8:35 pm
hey tassie
any chance of posting up the ID & OD of you spacers when they arrive,
cheers mate
Post Posted: Thu Jun 27, 2013 9:02 pm
i may leave the front as is then bar the springs and spacers then and see what happens, cheers
Ausuki wrote:
hey tassie
cheers mate
hey aussie i can do that for u now they have the measurements on ebay.
Will raise your vehicle by 30mm Front and Rear.
2 x Front 15mm AND 2 x Rear 30mm.
OD 108mm and ID 65mm
http://www.ebay.com.au/itm/380157088817 ... 1439.l2649
however i can not tell u if that is the same front to rear or not until i receive them probably next friday
Post Posted: Thu Jun 27, 2013 9:03 pm
So for say a 50mm lift. 50mm spacers in the rear and 25mm in the front for equal lift?
Post Posted: Thu Jun 27, 2013 9:10 pm
there abouts, i reckon 50mm & 30-35mm for the front to get it sitting level as the spring isn't exactly 1/2 along the control arm... it's further out towards the balljoint, but in saying that i've never messed around with them.
Post Posted: Thu Jun 27, 2013 9:12 pm
the rear needs double the lift the front needs (@ the springs) to get the same amount of height at the wheels if this makes sence.
if u get 2" Lift springs the front ones are more than likely only 1" longer than stock
its all to do with the ifs and how the leverage works
thanks mate
Post Posted: Thu Jun 27, 2013 9:13 pm
Depends on the car.
IE where the springs are.
On a Vit the front are well underneath, so 15mm at spring, gives 30mm at wheel.
But at the back, spring is close to wheel, so 30mm is 30mm.
Post Posted: Thu Jun 27, 2013 9:15 pm
christover1 wrote:
Depends on the car.
i was trying to say that u did a much better job of explaining it tho
Post Posted: Thu Jun 27, 2013 9:23 pm
reference pic of the location of the spring seat on calmini arms & SV Vitara arms, the SE arms are slightly different but the spring sits in about the same spot from memory.
Post Posted: Thu Jun 27, 2013 9:49 pm
Sweet.
Are the spacers same dimensions front to back? Disregarding height.
Post Posted: Fri Jun 28, 2013 3:17 pm
SierraDan wrote:
Sweet.
spacers are identical front to rear only the rear are twice as thick ;)
how do i put these on the front i undone the strut expecting the wishbone to just drop out of the way and to say the least it did not,
will the wishbone drop further if i disconnect the front sway bar or will i need spring compressors?
also is there an adjustment for the steering stops? i could not find 1 and i need to limit my steering lock to stop the tyres hitting the chassis on full lock.
Post Posted: Fri Jun 28, 2013 3:22 pm
front sway and it you need more bottom ball joint is only 3 bolts
steering look is on the pitman arm ??
Post Posted: Fri Jun 28, 2013 3:43 pm
Can't unbolt the ball joints on a sv as pictured above, you'll need to separate the ball joint from the taper if you can't get it by removing the swaybar.
Steering stops are on the chassis & pitman arm.
Post Posted: Fri Jun 28, 2013 7:06 pm
thanks atari ill try just the sway bar and if i cant get it then ill go with the spring compressor (a friend has 1 i can use) :beer:
cheers mate the jeep has them on the knuckles so i was looking around there and couldnt find anything :oops:
ill wait until the springs come now since its such a pain was gonna throw the spacers in until they got here but its such a pita i dont wanna do it twice rear end will be easy just undo the shocks and will drop straight down :woohoo:
Post Posted: Thu Jul 04, 2013 5:21 am
i drop the chassis end of the arm.
it lets u drop it down heaps more .
Post Posted: Thu Jul 04, 2013 1:07 pm
hey guys update coils and spacers fitted now sitting 2.5" higher also fitted 30mm bump stop extensions (in rear only) and flexed it up to check it at full compression and squashing the bump stop i have about half inch of clearance from my side lugs on tyre to the lip on the inner side of my wheel arch (29.5 x 9.5 standard rims and 2.5" lift and 30mm bump stop extensions) i also have about 2 foot of flex with standard shocks will go hunting for some shocks that are a little longer later on i think VL shocks will be too long and bottom out before my bump stops.
pictures on my rig page:
viewtopic.php?f=4&t=41421
Post Posted: Sat Jul 06, 2013 5:35 pm
today i found out that xj cherokee coil spacers with fit a vitara with a bit of minor trimming (of the spacer)
Post Posted: Sat Jul 06, 2013 8:20 pm
thats good to know i was looking into this before.
just remember the rear spacers on the vitara need to be twice as thick as the front to give an even lift
fit spacers to the rear the exact height u want to lift the car and put spacers in the front exactly half that size
Users browsing this forum: No registered users and 23 guests
