| Author |
Message |
Emmyrat
Vehicle: 99 suzuki grand vitara
 Posted: Fri Oct 25, 2013 8:02 am |
G'day does anyone know if extended sway bar links are available, my 1st time on site, let me know if I have stuffed up. Thanks Ian
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13015 Location: Melbourne
 Posted: Fri Oct 25, 2013 8:40 am |
Not as far as I am aware, but they aren't required for a body lift.
ninjamoses
Joined: Mon Aug 13, 2007 11:30 pm Posts: 1787 Location: Butler, WA
 Posted: Fri Oct 25, 2013 8:57 am |
As above  No off the shelf longer links are available. Spacer blocks are available for the sway bar mounts though which has the same effect. Probably wouldn't bother though unless you were doing a largish suspension lift (over 2")
fordem
Joined: Mon Apr 19, 2010 11:30 pm Posts: 2659 Location: Georgetown, Guyana
 Posted: Fri Oct 25, 2013 11:28 am |
The end link is nothing special - if you want a longer one - remove one and take it to your local auto part store, they'll find you one - at least the stores here will.
You don't need one for a body lift - the sway bar is attached to the frame - a suspension lift is a different matter - the end links are under the control arms so as the arms move down you probably need shorter links, although I suspect you will end up with contact between the bar and the arm if you go that route - spacer blocks between the mounts and the frame are probably your best bet.
Emmyrat
 Posted: Fri Oct 25, 2013 1:18 pm |
Thanks all, I just bought the vehicle and have never had anything to do with body lifts, there is a spacer between the sway bar and the chassis mounts that has been fabricated which was obviously for the suspension lift. Thanks again
atari4x4
 Posted: Fri Oct 25, 2013 4:49 pm |
is this GV of your silver by any chance & did it come from QLD?
Emmyrat
 Posted: Fri Oct 25, 2013 5:42 pm |
Oh god, what are you going to tell me about it.
Emmyrat
 Posted: Fri Oct 25, 2013 6:51 pm |
Not sure if my last post made it, did you get my reply bluesuzy
