It is currently Sat Oct 31, 2026 6:11 am
Vehicle: 99 suzuki grand vitara
Post Posted: Fri Oct 25, 2013 8:02 am
G'day does anyone know if extended sway bar links are available, my 1st time on site, let me know if I have stuffed up. Thanks Ian
Post Posted: Fri Oct 25, 2013 8:40 am
Not as far as I am aware, but they aren't required for a body lift.
Post Posted: Fri Oct 25, 2013 8:57 am
As above :)
No off the shelf longer links are available. Spacer blocks are available for the sway bar mounts though which has the same effect.
Probably wouldn't bother though unless you were doing a largish suspension lift (over 2")
Post Posted: Fri Oct 25, 2013 11:28 am
The end link is nothing special - if you want a longer one - remove one and take it to your local auto part store, they'll find you one - at least the stores here will.
You don't need one for a body lift - the sway bar is attached to the frame - a suspension lift is a different matter - the end links are under the control arms so as the arms move down you probably need shorter links, although I suspect you will end up with contact between the bar and the arm if you go that route - spacer blocks between the mounts and the frame are probably your best bet.
Post Posted: Fri Oct 25, 2013 1:18 pm
Thanks all, I just bought the vehicle and have never had anything to do with body lifts, there is a spacer between the sway bar and the chassis mounts that has been fabricated which was obviously for the suspension lift. Thanks again
Post Posted: Fri Oct 25, 2013 4:49 pm
is this GV of your silver by any chance & did it come from QLD?
Post Posted: Fri Oct 25, 2013 5:42 pm
Oh god, what are you going to tell me about it.
Post Posted: Fri Oct 25, 2013 6:51 pm
Not sure if my last post made it, did you get my reply bluesuzy
Users browsing this forum: No registered users and 464 guests
