| Author |
Message |
zuki
Joined: Thu Sep 25, 2008 11:30 pm Posts: 370 Location: Ipswich
 Posted: Sat Aug 15, 2009 1:43 am |
Could anyone shed some of the possible causes for Low Range to be jumping out while wheeling.
Cheers David
_________________ Zuki
Suzuki Sierra 1990 Hardtop
Now just drive i
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Sat Aug 15, 2009 1:46 am |
Could be anything from worn shims in the transfer to shifter sheet or even bodylift.
zuki
 Posted: Sat Aug 15, 2009 1:50 am |
Yeah I was leaning towards Shifter Sheet but the issues is in a mate of my son's NT sierra with NO body lift.
David
Now just drive i
Mike
lesspostingmorewheeling
Joined: Tue May 06, 2008 11:30 pm Posts: 2236 Location: Under Down Under
 Posted: Sat Aug 15, 2009 1:53 am |
if i wasn't a cheap suzuki owner i'd put money on it being the shifter sheet
_________________ [quote="Fluffy"] yeah right mate like Im gunna mov
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Sat Aug 15, 2009 2:17 am |
when i did the gears with my uncle he didn't do up all the 4 bolts on the DS so every time i accelerated it rocked forward and knocked it out of gear. simple but irritating all the same
jimbo_jones
Joined: Sat Jul 19, 2008 11:30 pm Posts: 4361 Location: gong
 Posted: Sat Aug 15, 2009 3:29 am |
could be a bent transfer bracket cousing the shifter to tuch tunnel under load seen that before on my mates
unique_seek
Joined: Mon Feb 16, 2009 10:30 pm Posts: 537 Location: Sunny Coast
 Posted: Sat Aug 15, 2009 1:49 pm |
do you have a body lift?my old sierra ute did this...cheap fix was to put 2 eye hooks and a rubber strap with 2clips(you get them from bunnings) and you just clip it in to 4wd low...but i would be looking at transfer mounts...i had the same prob on my coily when i did a body lift..ended up changing the shape wth an oxy...have to be very careful though,because they are 2piece with rubber joining the 2 pieces...
Try taking off your 4wd boot off..and see if the lever hits the body...may even be ok with out the extra width of the boot...you can also do some body work...bit dodgy though....
Good luck
_________________ Coily GTI Turbo...thats right its a coily!!
Westie
Joined: Tue Jul 04, 2006 11:30 pm Posts: 1417 Location: Caloundra Sunshine
 Posted: Sat Aug 15, 2009 10:08 pm |
unique_seek wrote: do you have a body lift?my old sierra ute did this...cheap fix was to put 2 eye hooks and a rubber strap with 2clips(you get them from bunnings) and you just clip it in to 4wd low...but i would be looking at transfer mounts...i had the same prob on my coily when i did a body lift..ended up changing the shape wth an oxy...have to be very careful though,because they are 2piece with rubber joining the 2 pieces... Try taking off your 4wd boot off..and see if the lever hits the body...may even be ok with out the extra width of the boot...you can also do some body work...bit dodgy though.... Good luck
what the hell is the rubber strap and eye bolts , is that a proffessional way of doing it cause you went and purchased parts
_________________ Steve W
Mattmorgo
Joined: Fri May 15, 2009 11:30 pm Posts: 464 Location: Southside Brisbane- the best side of the river
Vehicle: Shitbox
 Posted: Sun Aug 16, 2009 10:13 pm |
Ive just got back from a weekend of wheeling and found this to all day Friday low range was fine then last Saturday i couldn't go over a bump without it dropping back into neutral. i never had this problem before so i don't think its the body lift so my next bet would be shifter sheet? is there any easy way of finding out what the problem is?
MUDSKPA
Vehicle: Suzuki sierra sj70
 Posted: Wed Aug 27, 2014 8:54 am |
I'm having this same problem with my sj70 sierra and someone told me it could even be the shifter bushing?
1992suzukivitara
Vehicle: 1992 suzuki vitara
 Posted: Wed Aug 27, 2014 11:27 am |
Okey strap to hold it in mate
Cheers Joel!!
atari4x4
 Posted: Wed Aug 27, 2014 5:23 pm |
Could be the shifter sheet.
mazdaspater
Joined: Mon Feb 14, 2011 3:40 am Posts: 95 Location: Canberra
 Posted: Wed Aug 27, 2014 9:59 pm |
1992suzukivitara wrote: Okey strap to hold it in mate
Cheers Joel!! I remember driving a Baja bug out of the workshop one day pushing the brake pedal with my hand trying to find the key with my other hand when I was tuning the Webers and it jumped into gear and took off. Dived in through the window in a panic. Occy strap around the gearstick to stop it popping out of fourth. And to make it pop into second when you rev it in neutral. Rev, Rev, Clunk. front wheels off the ground. Shiiiit... Stupid Volkswagens.
