| Author |
Message |
Bugsta
Joined: Fri Oct 30, 2009 10:30 pm Posts: 1754 Location: North Brisbane
 Posted: Thu Dec 12, 2013 9:16 pm |
Australian Jimny Gearing
Bugsta
 Posted: Thu Dec 12, 2013 9:19 pm |
I have also pointed out that the auto VVT transfer case has a chain about 5mm narrower than the manual case. I also believe that the non VVT cases are also narrower. I have yet to confirm if they are the same in width or length.
Dan85
Joined: Mon Sep 10, 2012 8:43 pm Posts: 389 Location: laurieton
Vehicle: 2012 jimny
 Posted: Sun Dec 15, 2013 7:05 pm |
Bugsta wrote: Quote: Jimny NON VVT, High 1.32, Low 2.145 Jimny Manual VVT, High 1.0, Low 2.002 Jimny Auto VVT, High 1.27, Low 2.54
Sierra 1.3, High: 1.409, Low: 2.268 Sierra 1.0, High: 1.590, Low: 2.558 So given my 2012 jimny auto has a 1.27 transfer ratio in high and 2.54 ratio in low if I got a sierra 1.0 tranfer in with stock gearing i would be about 25% reduction in high and a approx 1% reduction in low? and with a 1.3 transfer stock gearing it would be a approx 11% reduction in high but approx 10-11% taller in low? Am I on the right track or should I put the beer down and read a book? gearing ratio stuff confuses me no end.
Bugsta
 Posted: Mon Dec 16, 2013 6:57 am |
Yes. Its all just maths.
You're only benefit would come from a gear set in one of the boxes, giving you reduction in both.
Blakey
Joined: Sun Mar 04, 2012 6:11 pm Posts: 464 Location: Brisbane, Petire
 Posted: Mon Dec 16, 2013 8:41 am |
I don't under stand why people use percentages its much easier to see it in ratios and far more simple to understand.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Mon Dec 16, 2013 7:00 pm |
Because it's easy to work tyre size correction in percent when talking about high range.
Personally I use percentage for high range and ratio for low.
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5946 Location: Northcliffe, W.A.
 Posted: Mon Dec 16, 2013 9:28 pm |
Gwagensteve wrote: Because it's easy to work tyre size correction in percent when talking about high range.
Steve. Exactly all of this.
Dan85
Vehicle: 2012 jimny
 Posted: Fri Dec 20, 2013 6:19 pm |
cool thanks guys.comforting knowing I was on the right track.
