It is currently Fri Oct 23, 2026 3:59 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
Post Posted: Thu Dec 12, 2013 9:16 pm
Australian Jimny Gearing
Post Posted: Thu Dec 12, 2013 9:19 pm
I have also pointed out that the auto VVT transfer case has a chain about 5mm narrower than the manual case. I also believe that the non VVT cases are also narrower. I have yet to confirm if they are the same in width or length.
Vehicle: 2012 jimny
Post Posted: Sun Dec 15, 2013 7:05 pm
Bugsta wrote:
Jimny NON VVT, High 1.32, Low 2.145
Jimny Manual VVT, High 1.0, Low 2.002
Jimny Auto VVT, High 1.27, Low 2.54
Sierra 1.3, High: 1.409, Low: 2.268
Sierra 1.0, High: 1.590, Low: 2.558
So given my 2012 jimny auto has a 1.27 transfer ratio in high and 2.54 ratio in low if I got a sierra 1.0 tranfer in with stock gearing i would be about 25% reduction in high and a approx 1% reduction in low? and with a 1.3 transfer stock gearing it would be a approx 11% reduction in high but approx 10-11% taller in low? Am I on the right track or should I put the beer down and read a book? gearing ratio stuff confuses me no end.
Post Posted: Mon Dec 16, 2013 6:57 am
Yes. Its all just maths.
You're only benefit would come from a gear set in one of the boxes, giving you reduction in both.
Post Posted: Mon Dec 16, 2013 8:41 am
I don't under stand why people use percentages its much easier to see it in ratios and far more simple to understand.
Post Posted: Mon Dec 16, 2013 7:00 pm
Because it's easy to work tyre size correction in percent when talking about high range.
Personally I use percentage for high range and ratio for low.
Post Posted: Mon Dec 16, 2013 9:28 pm
Exactly all of this.
Vehicle: 2012 jimny
Post Posted: Fri Dec 20, 2013 6:19 pm
cool thanks guys.comforting knowing I was on the right track.
Users browsing this forum: No registered users and 172 guests
