| Author |
Message |
zookeville
Vehicle: Sierra
 Posted: Wed Jan 08, 2014 4:02 pm |
what would you all advise as a most bang for your buck set of reduction gears for a 1989 suzuki sierra with 30" tyres that is used as a daily driver and future beginner offroading? thanks, Jake
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13007 Location: Melbourne
 Posted: Wed Jan 08, 2014 4:11 pm |
Probably 4.9:1
Depends on how steep your local terrain is though. If it's not super steep you could run 4.1
zookeville
Vehicle: Sierra
 Posted: Wed Jan 08, 2014 4:18 pm |
Any brands that are tried and true, and good for money that i should look at?
pezz
Joined: Fri May 15, 2009 11:30 pm Posts: 2108 Location: western vic
Vehicle: sj51
 Posted: Wed Jan 08, 2014 6:08 pm |
i run 30's with trail gear 4.9:1 gears, they are great. i got them from low range off road
whincup
Joined: Sat Apr 17, 2010 11:30 pm Posts: 1588 Location: Gracemere, QLD
Vehicle: '94 suzuki maruti
 Posted: Wed Jan 08, 2014 9:48 pm |
Gwagensteve wrote: Probably 4.9:1
Steve. on lowrangeoffroad, thats the most expensive ratio, even moreso than the 6.5's. its the set i wanted, but settled for the 4.1's since they were nearly $200 cheaper. or, it was when i bought the gears.
303zuke
 Posted: Fri Jan 10, 2014 11:41 pm |
whincup wrote: Gwagensteve wrote: Probably 4.9:1 Steve. on lowrangeoffroad, thats the most expensive ratio, even moreso than the 6.5's. its the set i wanted, but settled for the 4.1's since they were nearly $200 cheaper. or, it was when i bought the gears. Current prices from Low Range Offroad site (in US $): 4.16 = $399 4.9 = $525 5.14 = $629 6.5 = $599
zerohex555
Vehicle: suzuki, jimny 1998
 Posted: Mon Jan 13, 2014 3:32 pm |
What about for a jimny that is going to have 3 to 4inch lift with 30" a/t's?
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Mon Jan 13, 2014 3:43 pm |
^none of those gear fit without a sierra Tcase swap...
$1200 for gears in a jimny case
zerohex555
 Posted: Tue Jan 14, 2014 11:45 am |
Where can I get them, name and size if you know. would like to explore both options.
tanshi
 Posted: Tue Jan 14, 2014 11:56 am |
think the company is called trial jimny.
Gwagensteve
 Posted: Tue Jan 14, 2014 12:56 pm |
Trial jimny do the 24% chain swap- low and high both drop 24%
Apio do a replacement planetary that drops low range only.
Combining both is über awesome, but makes your transfer case worth one million dollars.
