It is currently Wed Oct 14, 2026 4:38 pm
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3  Next
Vehicle: Suzuki Jimny 2009
Post Posted: Mon Apr 28, 2014 9:46 pm
Zukenutter, feel free to pioneer the Jimny rear sway bar. This seems to be the best approach after Steve explained the issues to me. Steve suggested attaching it to the tow bar and then the shock mounts or radius arm bolts. Just need to work out what bar from what car will fit and sort out all the mountings. Not something I have time to tinker with at present. Might need to start a new thread for it.
Mike
Post Posted: Tue Apr 29, 2014 6:01 am
Tow bar was what is had been thinking too.
Vehicle: On the lookout
Post Posted: Tue Apr 29, 2014 8:36 am
I've bought stuff from asian countries like that before when I bought a heap of 'MIC' jimny stuff. If anyone wants it in Black instead of Red, just ask, I'll bet they'll spray yours in black no problems. Pretty sure they will be making them to order.
Vehicle: jimny
Post Posted: Fri May 02, 2014 9:12 pm
getting ack to the original question does anyone have any before and after pics with either of the aftermarket arms showing the bent front springs with original arms and how straight they make them with aftermarket ones and how far they move the axle forward
Post Posted: Sat May 03, 2014 7:40 pm
Best pic I could take with the wheel on. Old design ORA arms. They are the 4" set
Vehicle: jimny
Post Posted: Tue May 06, 2014 7:40 pm
Ok yeah thats way better than my 3in lift with orig arms will prolly go with the jimny bits arms seems they around the $600 mark delivered
Post Posted: Tue May 06, 2014 7:48 pm
Have you priced the new ORA arms at all? Just wondering how much they are.
Post Posted: Tue May 06, 2014 8:13 pm
u got some rust in there happening aye o.O
Post Posted: Tue May 06, 2014 8:25 pm
She sees a lot of salt. Everything that's not bolted to the body or chassis is a bit orange :( really shows how effective the ERPS is at protecting the body and chassis.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed May 07, 2014 8:16 am
this might give some idea of the jb dimentions vs stock. jb installed, and stock hanging off the tail of the front bolts
Vehicle: jimny
Post Posted: Sat May 10, 2014 7:39 pm
Ora arms were close to $800 delivered i have ended up ordering front and rear jb arms and a 25mm tailshaft spacer delivered $830 to nsw. i still need bushes id prefer genuine anyone got any used had experience with alternatives?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sat May 10, 2014 9:25 pm
you can press out and reuse the bushes you already have if their in ok condition. i see no value in rear arms.
prop spacer goes in the front
Vehicle: Suzuki Jimny 2010
Post Posted: Sun May 11, 2014 12:35 am
PM Bruce for bushes... You won't be disappointed ;)
Post Posted: Tue May 13, 2014 3:07 pm
what about a 5 link set up ??
ive seen if on the Zanfi Group FB page looks pretty wild, all the jap jimnies run them...
you could just buy a couple TD adjustable panhards and some 8-10MM plate and go from there
Post Posted: Tue May 13, 2014 6:17 pm
Are you talking about that hideous bolt on 5-link?
Post Posted: Wed May 14, 2014 8:45 am
im not sure what kit your talking about. i was just going to make one up from TD rods and plate.....
Post Posted: Wed May 14, 2014 9:31 am
If only it was that easy
Do you have a good fabrication background? How much research have you done on how to build your own suspension?
Post Posted: Wed May 14, 2014 3:27 pm
yea spent 3 year welding up trucks and trailers, and fixing there suspension, have a fair idea, never attempted it before though, so no real experience, that's why im on here...i rekon we could nut it out, how hard can it be....the Japanese kit doesn't look overly complex..
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed May 14, 2014 4:28 pm
depends how wll you want it to work onroad
Post Posted: Wed May 14, 2014 9:01 pm
Got a link to the jap kit in question?
Post Posted: Fri May 16, 2014 8:07 am
like dis
Post Posted: Fri May 16, 2014 8:50 am
My god, how floppy would that be!
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri May 16, 2014 9:12 am
http://www.aliexpress.com/item/3-to-6-i ... 25201.html
good luck,
Post Posted: Fri May 16, 2014 4:35 pm
Not the one I was thinking... It bolted to the bottom of the chassis and created more hang up than flex lol
Post Posted: Fri May 16, 2014 9:16 pm
Does that bolt on at the beginning of the chassis wheel hump?
Post Posted: Fri May 16, 2014 9:48 pm
That's not even a Jimny
Have a look at the where the radius arm"would" bolt up on the rhs of the that pic
Post Posted: Fri May 16, 2014 10:06 pm
Wicked geometry there
Vehicle: jimny
Post Posted: Sat May 17, 2014 9:53 am
Lol wish i had chrome shocks, so my jb arms turned up they look pretty good theyre heavier than i thought very solid construction. i price genuine rubber bushes(12) from penrith suzuki will have to rder them in $546.00 priced jb rubber ones delivered $655.00 what is everyone else running id prefer rubber and whatd you pay
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sat May 17, 2014 3:31 pm
I just jb to press in standard bushes. Their softer then polly and that means the flex better.
Post Posted: Sun May 18, 2014 6:41 am
If you're referring to the coil sierra photo that Jim_Aus posted, they're not chrome shocks, they're airshocks.
Heavily inclined, inboard air shocks+no swaybar+no roll stiffness from the suspension=massive flops
Users browsing this forum: No registered users and 246 guests
