It is currently Fri Jul 24, 2026 5:12 pm
Post Posted: Sat May 10, 2014 2:12 pm
Main/ high beam globe working... Check
Indicator globe working... Check
Yep... you know what I'm about to ask
How the hell do you replace the parking light bulb on a 94 Vitara... and if the answer is remove the head light assembly how do you do that...??
Vehicle: SJ80, SE416
Post Posted: Sat May 10, 2014 2:18 pm
The park globe is between the headlight and indicator globe - access from next to the indicator globe but you can't get to it with the black plastic shorud on the rear of each headlight in the way. You need to remove the plastic shroud from around the rear of the headlight - crap task I know.
What I did was remove the grill so as to access the front trim-clips on the black plastic headlight shroud. It's a crap job just to replace a globe, but I did cut a slot in the middle of each plastic shroud so in future I can reach in there and twist out the globe holder just like with the indicator globe. No tools required then!
I think on the drivers side the washer bottle and horn had to come out as well so I could get in there!
Alternatively you could also remove the plastic shrouds altogether, but if you modify them you won't have any problem accessing the park globe in the future.
Post Posted: Sat May 10, 2014 2:31 pm
Ah... I see.
I had a look earlier on removing the grill but couldn't find the bolts/ screws for it. Maybe I can get a sharp Stanley knife or something and trim the plastic back... or am I likely to rip into the wiring or something doing that?
I reckon that the designer thought this would be a great laugh... maybe he knew he was getting sacked and this was his last hurrah!
Post Posted: Sun May 11, 2014 5:11 pm
Shouldnt need to remove anything at all? Mines a 95 swb, i just twist the plug from the light assembly then pull the globe.
Post Posted: Sun May 11, 2014 5:18 pm
That's true for the headlight and indicator but not for the parking lighjt
Post Posted: Sun May 11, 2014 6:19 pm
Or someone's already removed the plastic bits...
Post Posted: Sun May 11, 2014 7:08 pm
Nope 100% sure i havent removed anything, take a pic for me?
Users browsing this forum: Jezzer and 423 guests
