| Author |
Message |
Toby96
Joined: Tue Feb 04, 2014 7:10 pm Posts: 10 Location: Brisbane
Vehicle: '95 Suzuki Sierra
 Posted: Tue May 13, 2014 4:14 pm |
As it says, I replaced all 6 uni joints (They were loose and on the verge of breaking) with Toyo ones. It never vibrated beforehand whilst driving but now it starts excessively vibrating like I'm an earthquake on wheels. It starts up around the 70kmh - 80kmh mark.
Is this normal for new uni's to do - as in do they need to be worn in? Or should I be contacting the bloke who fitted them and getting him to do something about it?
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Tue May 13, 2014 4:19 pm |
No it's not normal. Something has new incorrectly assembled.
tanshi
 Posted: Tue May 13, 2014 4:25 pm |
sounds like one of them is too tight or off centre. get it fixed
Toby96
 Posted: Tue May 13, 2014 4:31 pm |
Cheers for the input guys, Will give him a call tonight and get it dropped in ASAP.
johnmath
Joined: Mon Jan 30, 2012 12:49 pm Posts: 161 Location: Parkside
Vehicle: Suzuki/Sierra/1988 SJ50 HiTop
 Posted: Tue May 13, 2014 5:08 pm |
If the front and rear uni yokes are not aligned correctly, you will get bad vibration. Were the shaft halves separated at the sliding spline? If so, check they were reassembled with the splines lined up with the reference marks so that the yokes are phased properly (check the service manual for diagrams).
flymaster
Vehicle: Suzuki Sierra Trayback
 Posted: Tue May 13, 2014 7:13 pm |
Toby96
 Posted: Tue May 13, 2014 7:33 pm |
Care to elaborate on the shaft halves at the sliding spline? I'm not that car-savvy, first car and only recently got licensed so this is all new to me! The shaft had been separated into 3 separate pieces from what I saw in the photos, if that helps.
Mickc
Joined: Fri Jun 03, 2011 8:18 pm Posts: 107 Location: brisbane
 Posted: Tue May 13, 2014 8:41 pm |
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Tue May 13, 2014 8:55 pm |
Prob used the uni clips supplied with the new unis they never sit right I always re use the factory ones if there still in good nick
kenn
Joined: Tue Nov 11, 2008 10:30 pm Posts: 1202 Location: Melbourne
 Posted: Tue May 13, 2014 9:04 pm |
While he's fixing it get him to take those crappy Toyo things out and put factory ones in..
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Wed May 14, 2014 2:57 am |
What suburb do you live in
Teracis
Joined: Sat Dec 11, 2010 10:03 pm Posts: 2261 Location: Gold Coast
Vehicle: Daisy
 Posted: Wed May 14, 2014 6:17 am |
If the shafts appear to be in phase and they can't find anything wrong with the uni's, check for play in the splined shaft section, I had a front driveshaft with heaps of play in the splined section, I didn't realise we'd left the hubs locked in (it had never been a problem before because we were only wheeling slowly) and when I hit 60-70km/h on the road it felt like the whole truck was going to shake apart.
I turned around, went home, took another car because I was in a hurry, checked it the next morning in the light, saw what was wrong. I'm not saying that's your problem, just stating another option.
Toby96
 Posted: Wed May 14, 2014 10:00 am |
I'm in Thornlands, Redland Bay Area. Dropped it into the shop today at 8 and they're going to pull it all apart again and go over it. It was the apprentice who installed it last time. The guy looking after it said that the shaft may need balancing and that's what might be causing it?
Cheers Teracis, will do.
MrRocky
 Posted: Wed May 14, 2014 11:58 am |
I call bullshit, bet the apprentice dropped the internal rollers and stuffed it. They vibrate when there tight as well
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Wed May 14, 2014 12:19 pm |
kenn wrote: While he's fixing it get him to take those crappy Toyo things out and put factory ones in.. Whats wrong with Toyo Unis?
_________________ mlm
jdk81
Joined: Sat Jul 18, 2009 11:30 pm Posts: 2372 Location: Ballarat, VIC
 Posted: Wed May 14, 2014 12:49 pm |
MrRocky wrote: I call bullshit, bet the apprentice dropped the internal rollers and stuffed it. They vibrate when there tight as well +1 Its easy to have a roller fall down etc, a miss-lodged roller can also fall and then poke up into the grease hole. I bet the installer fucked it up and are blaming the apprentice or something else that you have to pay for.
Toby96
 Posted: Wed May 14, 2014 2:06 pm |
Didn't pay for the fix, owner of the garage is a family friend. One of the clips wasn't in properly and was causing it to rattle, got the car back about 4 hours later and it's now gone.
kenn
 Posted: Fri May 16, 2014 7:46 pm |
SierraDan wrote: kenn wrote: While he's fixing it get him to take those crappy Toyo things out and put factory ones in.. Whats wrong with Toyo Unis? They fail, had one go in about 100 k's replaced it with a second hand factory one at camp and that lasted about 2000k's before I took it out still in good nic and replaced it and the three other Toyo's as another one had failed, the other two weren't in very good condition either. I'm still running the factory ones today even after upgrading to coils.
SierraDan
 Posted: Fri May 16, 2014 10:08 pm |
Yours failed. Mine are good!
