It is currently Thu Oct 15, 2026 9:48 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri May 23, 2014 8:50 am
its a slightly less finished look, but the thing is you dont have to chop it all off at once. you can do the steel all at once then go out, flex up on things and trim where you see it scrubbing.
you can take your time and get it right rather then just going the whole goat from day dot. the full bigjimny chop fits 31"s after all.
Vehicle: 2002 Jimny
Post Posted: Fri May 23, 2014 9:29 am
Good point Jeremy.
I'd worry that trying to trim less off may look a little less tidy, as it would be much easier to follow the line where the flat spot joins the curve, rather than trying to cut half of the flat etc.
But I might try this path. After all, you can always take more off, but can't put it back on.
Vehicle: 2002 Jimny
Post Posted: Fri May 23, 2014 4:09 pm
So I got everything ready today, popped the plastic flares off, all ready to go, and then had a thought. I will need to attach some form of flaring in order to cover the tyres completely, as they do protrude a little at this stage. If I do go ahead with the chop, then there will be nowhere elegant to mount a flare such as a Flexy Flare.
So really, just a little lift would probably be the ideal option for me.... Gahhh!
ZukeNutter - It looks like it's all standard under there. (photos uploading now)
Therefore, the coil spacers will not be a good option without at least correcting caster first?
Thanks guys!
Vehicle: 2002 Jimny
Post Posted: Fri May 23, 2014 4:15 pm
Pardon the mud...
Post Posted: Fri May 23, 2014 7:26 pm
Hard to tell with the mud but they look like adjustment bushes. You're an architect so you'll have a good eye, if the bolt is noticeably off centre in relation to the outer circumference of the bush then it's been corrected. Offset centre will be opposite when you compare the front bushes to the rear bushes.
Vehicle: 2002 Jimny
Post Posted: Sat May 24, 2014 9:56 am
Thanks for that ZN. Upon looking closer, it looks like they may have already been corrected.
The rear definitely looks off centre -
As does the front -
So, therefore coils spacers should be ok?
I stumbled accross your tech guide (viewtopic.php?f=5&t=11827), this was with 215 75 15's, right?
Post Posted: Sat May 24, 2014 10:17 am
Yeah should be ok. I had 215s when I did that tech thread but also ran 235s with the same setup. I've always had some degree of spacer. I've never had offset rims though.
Vehicle: 2002 Jimny
Post Posted: Sat May 24, 2014 10:20 am
Ok cool. Thanks again for all your help, mate.
Vehicle: 2002 Jimny
Post Posted: Mon May 26, 2014 5:23 pm
Hey guys - I have just finished trimming my front guards. For those who wanted to see how it turned out, check it out here -
viewtopic.php?uid=8204&f=5&t=46397&start=0
Users browsing this forum: Google [Bot] and 308 guests
