| Author |
Message |
minare
Vehicle: Jimny 09
 Posted: Tue Jul 29, 2014 10:28 pm |
jimny_timmy
Vehicle: Suzuki Jimny 2010
 Posted: Tue Jul 29, 2014 10:40 pm |
Looks better than some I've seen...
Jezza86
Platinum Supporter
Joined: Tue Dec 06, 2011 9:30 am Posts: 2155 Location: Nhulunbuy 0880
Vehicle: 2010 jimny
 Posted: Tue Jul 29, 2014 10:47 pm |
droop will still be limited by shock length ? i think the rig they use in those pics has a 6" lift. it would be interesting to drive and see how it goes, but this time im not going first. not keen to drill through the chassis rails.
_________________ your daily dose of questionable sanity
jimny_timmy
 Posted: Tue Jul 29, 2014 10:48 pm |
Longer shocks are easy... Commo shocks are too long already lol
Jezza86
Platinum Supporter
Vehicle: 2010 jimny
 Posted: Tue Jul 29, 2014 11:01 pm |
Yeh then spring retainers required so the spring is the shortest bit. I wanna see ttheir idea od stable
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Wed Jul 30, 2014 5:20 am |
Aren't you guys lacking rear roll stiffness as it is??
_________________ mlm
Jezza86
Platinum Supporter
Vehicle: 2010 jimny
 Posted: Wed Jul 30, 2014 7:05 am |
im not, but in general most jimnys are.
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Wed Jul 30, 2014 9:14 am |
Jimnys have good roll stiffness, for road use. And off road the rear seems about right.
Buy it and let us know how it feels? I think it would drive under itself and be spooky on hills.
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Wed Jul 30, 2014 11:07 am |
That bracket that requires drilling the chassis would be so much better designed if it accepted a square u-bolt or two to clamp it to the chassis instead...
monley
Joined: Wed Nov 24, 2010 7:58 am Posts: 11092 Location: Mandurah.W.A.
 Posted: Wed Jul 30, 2014 2:20 pm |
alien wrote: That bracket that requires drilling the chassis would be so much better designed if it accepted a square u-bolt or two to clamp it to the chassis instead... Yeh that would be a great idea then the bracket could move around while your driving
_________________ Tell my arse, he actually gives a crap!
alien
 Posted: Wed Jul 30, 2014 2:44 pm |
How? Doesn't it pick up a factory bolt hole at the far end? (Screws up from the bottom). That would locate it laterally, then the U-bolt would clamp it to the chassis.
Just saying, wouldn't take much more thought to better engineer to avoid drilling the chassis.
Jezza86
Platinum Supporter
Vehicle: 2010 jimny
 Posted: Wed Jul 30, 2014 4:23 pm |
Nah it bolts up further back on the chassis then the origional rear arm mounts It has to because otherwise its not 4 link. The lower arms use the origional mount
Jezza86
Platinum Supporter
Vehicle: 2010 jimny
 Posted: Wed Jul 30, 2014 4:31 pm |
Can you imagine how popular a larger then stock, cheap fuel tank would be!
SierraDan
 Posted: Thu Jul 31, 2014 5:12 am |
alien wrote: Just saying, wouldn't take much more thought to better engineer to avoid drilling the chassis. Like weld it on?
alien
 Posted: Thu Jul 31, 2014 8:00 am |
I was thinking more so it was reversible given next to no jimnys on here are engineered. But a bolt on solution without drilling/welding would also make it more attractive for people to fit themselves (then again that may not be a good thing).
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13008 Location: Melbourne
 Posted: Thu Jul 31, 2014 8:40 am |
I think how it's mounted isn't as important as is it necessary in the first place. Considering the rear arms/bushes of a jimny provide more travel than the spring design can use, and the Jimnys I've seen suffered from inadequate rear roll stiffness, I'd say this is a pointless part.
