It is currently Wed Aug 05, 2026 12:07 pm
Vehicle: Jimny 09
Post Posted: Tue Jul 29, 2014 10:28 pm
Hey all,
Has anyone have an experience with rear 4 link conversion as the following links?
and what are the impressions
http://www.aliexpress.com/store/product ... 52609.html
http://item.rakuten.co.jp/hb-1st/877761/
does anyone knows 3 or 4 link kit for front?
thanks
Guy :)
Vehicle: Suzuki Jimny 2010
Post Posted: Tue Jul 29, 2014 10:40 pm
Looks better than some I've seen...
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Jul 29, 2014 10:47 pm
droop will still be limited by shock length ?
i think the rig they use in those pics has a 6" lift.
it would be interesting to drive and see how it goes, but this time im not going first. not keen to drill through the chassis rails.
Post Posted: Tue Jul 29, 2014 10:48 pm
Longer shocks are easy... Commo shocks are too long already lol
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Jul 29, 2014 11:01 pm
Yeh then spring retainers required so the spring is the shortest bit.
I wanna see ttheir idea od stable
Post Posted: Wed Jul 30, 2014 5:20 am
Aren't you guys lacking rear roll stiffness as it is??
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jul 30, 2014 7:05 am
im not, but in general most jimnys are.
Post Posted: Wed Jul 30, 2014 9:14 am
Jimnys have good roll stiffness, for road use. And off road the rear seems about right.
Buy it and let us know how it feels? I think it would drive under itself and be spooky on hills.
Post Posted: Wed Jul 30, 2014 11:07 am
That bracket that requires drilling the chassis would be so much better designed if it accepted a square u-bolt or two to clamp it to the chassis instead...
Post Posted: Wed Jul 30, 2014 2:20 pm
Yeh that would be a great idea then the bracket could move around while your driving :roll:
Post Posted: Wed Jul 30, 2014 2:44 pm
How? Doesn't it pick up a factory bolt hole at the far end? (Screws up from the bottom). That would locate it laterally, then the U-bolt would clamp it to the chassis.
Just saying, wouldn't take much more thought to better engineer to avoid drilling the chassis.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jul 30, 2014 4:23 pm
Nah it bolts up further back on the chassis then the origional rear arm mounts
It has to because otherwise its not 4 link.
The lower arms use the origional mount
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jul 30, 2014 4:31 pm
Can you imagine how popular a larger then stock, cheap fuel tank would be!
Post Posted: Thu Jul 31, 2014 5:12 am
Like weld it on?
Post Posted: Thu Jul 31, 2014 8:00 am
I was thinking more so it was reversible given next to no jimnys on here are engineered. But a bolt on solution without drilling/welding would also make it more attractive for people to fit themselves (then again that may not be a good thing).
Post Posted: Thu Jul 31, 2014 8:40 am
I think how it's mounted isn't as important as is it necessary in the first place. Considering the rear arms/bushes of a jimny provide more travel than the spring design can use, and the Jimnys I've seen suffered from inadequate rear roll stiffness, I'd say this is a pointless part.
Users browsing this forum: No registered users and 197 guests
