Print view
Previous topic | Next topic
| Author |
Message |
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13011 Location: Melbourne
 Posted: Mon Mar 23, 2015 4:08 pm |
I'm bored with this. I have run two of these pumps in series with the stock water pump removed with the 660, then the stock pump only with the 1.6, then one as a booster to the stock pump.
Car did weird cooling stuff with no booster pump on the 1.6
With the Bosch pump/pumps it stays/stayed cool.
Nothing bad happens. I run them constantly on (ign+Ve)
Nobody else has any experience with this part number and a rear mount radiator. Power consumption is minimal. No fancy switching, pressure, temperature or pump management is required. There's no need to make it more complicated or expensive.
SuziBlu
Joined: Mon Sep 14, 2009 11:30 pm Posts: 4268 Location: Eyre Peninsula
 Posted: Tue Mar 24, 2015 7:18 am |
ok Steve, once again, you are right, why should anyone doubt your wisdom. No discussion ever needed when you on the job hey.
_________________ Bad decisions make good stories.
Gwagensteve
 Posted: Tue Mar 24, 2015 7:58 am |
No problem Suziblu, happy to help.
Jezza86
Platinum Supporter
Joined: Tue Dec 06, 2011 9:30 am Posts: 2155 Location: Nhulunbuy 0880
Vehicle: 2010 jimny
 Posted: Tue Mar 24, 2015 8:55 am |
SuziBlu wrote: ok Steve, once again, you are right, why should anyone doubt your wisdom. No discussion ever needed when you on the job hey. speaking from a mechanical engineering stand point, he is right.
_________________ your daily dose of questionable sanity
jonno_racing
Joined: Wed Apr 15, 2009 11:30 pm Posts: 8164 Location: Tassie
 Posted: Tue Mar 24, 2015 9:11 am |
the only change i would potentially do is the same as i have set up the fans on dmfelix's car i run a temp switch on the thermostat housing to switch things on (his has a overide off switch 2) that would keep running times down to when "required" but im with steve full time would be mint.
_________________ Do cool stuff, Put it on the internet Sierra build, Jimny build https://www.youtube.com/user/redzook1
Joshyboy26
Joined: Thu Sep 01, 2011 11:48 pm Posts: 814 Location: kinglake, VIC
 Posted: Tue Mar 24, 2015 7:33 pm |
Hey steve how did you reduce the pipes down to 19mm?
Gwagensteve
 Posted: Wed Mar 25, 2015 5:56 am |
Just welded up some adapters using different pipe diameters- just bits of roll bar tube etc. you Might be able to see some of them in my build thread.
Users browsing this forum: No registered users and 141 guests
