| Author |
Message |
skitzlux
Joined: Sun Jun 07, 2009 11:30 pm Posts: 301 Location: bris
 Posted: Sat Sep 12, 2009 4:39 am |
what ratio does everyone run what size tyres do you have and can you do 100 with reasonable revs i wanna know what ratio i should get its a daily but i want it to be really capable aswel
hardknocks
Joined: Thu Jan 22, 2009 10:30 pm Posts: 58 Location: leura
 Posted: Sat Sep 12, 2009 10:55 am |
6.5:1 reduction gears , 31" , 100km / 4500rpm ,83kms on the speedo 100km
using gps . A little expencive but you will never look back , well worth it
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Sat Sep 12, 2009 12:59 pm |
W/T with 6.5's 3600 is 100kph on a gps and when it was a 1.3 would tow this no worry's at 90kph.
Rockhopper
Joined: Sun Jun 22, 2008 11:30 pm Posts: 1265 Location: Chipping Norton
 Posted: Sat Sep 12, 2009 1:13 pm |
6.5:1 with true 31" tyres. I've had my speedo recalibrated also. It does 100km/h at about 3500 - 3600 rpm and 110km/h at 3900 - 4000 rpm. Has a top speed of 130km/h
_________________ We're riding in the Ninky Nonk!
lump_a_charcoal
Joined: Wed Feb 28, 2007 10:30 pm Posts: 4454 Location: Botany, NSW
Vehicle: MY2019 Jimny
 Posted: Sat Sep 12, 2009 1:58 pm |
Mine will be 6.5 gears, 3.9 diffs, with 31s. Should be good.
Damo
Joined: Sat Jul 22, 2006 11:30 pm Posts: 4661 Location: Brisbane
 Posted: Sat Sep 12, 2009 2:19 pm |
lump_a_charcoal wrote: Mine will be 6.5 gears, 3.9 diffs, with 31s. Should be good.
And mine the same, but i'm going to 235/85R16 tyres. I seemed to be around 4000rpm @ 100kph.
_________________ SJ50.4.LYF
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Sat Sep 12, 2009 2:27 pm |
so if you missed it 6.5s are cool it you want to do 100 at about 3500-4000rpm, i would only run 6.5s again if i had 33 on zook standard diffs
BlueSuzy
 Posted: Sat Sep 12, 2009 2:33 pm |
I had my 6.5's 3.7 diffs with stockers before my 33's. Gears on road quickly run out..
With 33's. Much betterer. Im still in 5th gear about 60/70kmh though on flat ground.
My 1.6 helps though..
lump_a_charcoal
 Posted: Sat Sep 12, 2009 3:04 pm |
With 6.5s, you need to brace the Tcase though.
flexedup88
Joined: Thu Aug 13, 2009 11:30 pm Posts: 204 Location: adelaide
 Posted: Sat Sep 12, 2009 5:15 pm |
im running 30"s on my daily and have the same questions, im thinkin il go 4.9 gears and see how they go, with my 3.9 diffs it should go alrite.
mrw82
Joined: Tue Jul 03, 2007 11:30 pm Posts: 1350 Location: stuck in a hole. not off road, just deception bay.
 Posted: Sat Sep 12, 2009 6:34 pm |
im running 4.16 gears in a 1 litre 4.1 diff ratio, I have only 4 gears not 5 like you 1.3 boys. with 30" rubber. works well and I can do 100 but its screaming, seems to be comfortable at 90 and it's not pushing too hard to get there.
off road it's brilliant
in a 1.3 running 30's i'd be looking at 4.9's
shep
 Posted: Sat Sep 12, 2009 6:43 pm |
i don't understand why people don't like to rev Suzuki motors. my 1.6 is happy to rev at 4 grand all day. the red bit on the gauge doesn't start until 6500 so 4000 is stuff all.
rev em cos they love it.
atari4x4
 Posted: Sat Sep 12, 2009 6:48 pm |
shep wrote: rev em cos they love it.
BlueSuzy
 Posted: Sat Sep 12, 2009 8:18 pm |
atari4x4 wrote: shep wrote: rev em cos they love it.
steak_knife
 Posted: Sat Sep 12, 2009 9:10 pm |
steak_knife
 Posted: Sat Sep 12, 2009 9:15 pm |
My Gv sitts on about 3500 at 100kph, but then I change out of 3rd to 4th.
You guys would obliterate me off road tho, unless it was dirt roads, then no chance !!!! peaceout  peaceout
Taff
Joined: Sun Aug 13, 2006 11:30 pm Posts: 889 Location: Brisbane
 Posted: Sun Sep 13, 2009 7:25 pm |
shep
 Posted: Sun Sep 13, 2009 7:32 pm |
Taff wrote:
it is true though, the motor isn't a primitive push rod motor. hell i have had
Suzuki motors that would do 12000revs all day every day.
Taff
 Posted: Sun Sep 13, 2009 7:43 pm |
I run 30" tyres, 6.5 gears and 3.9 diff.
100 is around 4000rpm, it loves it.
xedent
Joined: Mon Jun 15, 2009 11:30 pm Posts: 895 Location: Sunshine Coast, QLD
 Posted: Tue Sep 22, 2009 3:01 am |
So with the 6.5's is it a must to the run brace on the transfer ? Is it hard to fit the brace.
cheers
_________________ My Maruti build, Click WWW
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Tue Sep 22, 2009 11:30 pm |
6.5's will bend the stock transfer arms if you have a 1.3.
I brace the longside arm by boxing it in, run urethane isolation mounts and a small tab off the longside arm that picks up 2 of the front output housing bolts.
This seems to be enough.
Here's a photo of a braced arm.
PS 1.0 litre sierras have 4 transfer mounts and don't seem to bend arms, regardless of gears or tyre size.
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Wed Sep 23, 2009 3:43 pm |
Gwagensteve wrote: a small tab off the longside arm that picks up 2 of the front output housing bolts.
Am I blind or has this not been done in that photo?
31zook
 Posted: Wed Sep 23, 2009 9:36 pm |
ScrawnC wrote: Gwagensteve wrote: a small tab off the longside arm that picks up 2 of the front output housing bolts. Am I blind or has this not been done in that photo?
yer maybe it's on the other side?
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Wed Sep 23, 2009 10:45 pm |
31zook wrote: ScrawnC wrote: Gwagensteve wrote: a small tab off the longside arm that picks up 2 of the front output housing bolts. Am I blind or has this not been done in that photo? yer maybe it's on the other side?
I doubt it.
How/why would a bracket reach past the shifter to the front output bolts?
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Wed Sep 23, 2009 11:03 pm |
boys I dont think that pic has the extra bracket, but im sure if you use you imagination youll work it out.
the rocky road beefed up arms use something similar with the extra bracket, but they use the rear output of the tc
want33s
 Posted: Wed Sep 23, 2009 11:29 pm |
Spidertrax transfer mount has served me well with 6.5 gears and double locked on 33's
steak_knife
 Posted: Wed Sep 23, 2009 11:53 pm |
want33s wrote: Spidertrax transfer mount has served me well with 6.5 gears and double locked on 33's
So your Got33`s now???
want33s
 Posted: Wed Sep 23, 2009 11:57 pm |
steknig wrote: want33s wrote: Spidertrax transfer mount has served me well with 6.5 gears and double locked on 33's So your Got33`s now???
Had Silverstone 33's now have Simex 32's...
Silverstone 33's were 31.5"
Simex 32's are 32.8"
Will be Want35s soon.
ajsr
 Posted: Thu Sep 24, 2009 1:14 am |
thats just gready jas
steak_knife
 Posted: Thu Sep 24, 2009 1:57 am |
ajsr wrote: thats just gready jas   That`s what i thort to.
