It is currently Fri Oct 09, 2026 3:22 pm
Post Posted: Sat Sep 12, 2009 4:39 am
what ratio does everyone run what size tyres do you have and can you do 100 with reasonable revs i wanna know what ratio i should get its a daily but i want it to be really capable aswel
Post Posted: Sat Sep 12, 2009 10:55 am
6.5:1 reduction gears , 31" , 100km / 4500rpm ,83kms on the speedo 100km
using gps . A little expencive but you will never look back , well worth it ;)
Post Posted: Sat Sep 12, 2009 12:59 pm
W/T with 6.5's 3600 is 100kph on a gps and when it was a 1.3 would tow this no worry's at 90kph.
Post Posted: Sat Sep 12, 2009 1:13 pm
6.5:1 with true 31" tyres. I've had my speedo recalibrated also. It does 100km/h at about 3500 - 3600 rpm and 110km/h at 3900 - 4000 rpm. Has a top speed of 130km/h
Vehicle: MY2019 Jimny
Post Posted: Sat Sep 12, 2009 1:58 pm
Mine will be 6.5 gears, 3.9 diffs, with 31s. Should be good.
Post Posted: Sat Sep 12, 2009 2:19 pm
And mine the same, but i'm going to 235/85R16 tyres. I seemed to be around 4000rpm @ 100kph.
Post Posted: Sat Sep 12, 2009 2:27 pm
so if you missed it 6.5s are cool it you want to do 100 at about 3500-4000rpm, i would only run 6.5s again if i had 33 on zook standard diffs
Post Posted: Sat Sep 12, 2009 2:33 pm
I had my 6.5's 3.7 diffs with stockers before my 33's. Gears on road quickly run out..
With 33's. Much betterer. Im still in 5th gear about 60/70kmh though on flat ground.
My 1.6 helps though.. :lol:
Post Posted: Sat Sep 12, 2009 3:04 pm
With 6.5s, you need to brace the Tcase though.
Post Posted: Sat Sep 12, 2009 5:15 pm
im running 30"s on my daily and have the same questions, im thinkin il go 4.9 gears and see how they go, with my 3.9 diffs it should go alrite.
Post Posted: Sat Sep 12, 2009 6:34 pm
im running 4.16 gears in a 1 litre 4.1 diff ratio, I have only 4 gears not 5 like you 1.3 boys. with 30" rubber. works well and I can do 100 but its screaming, seems to be comfortable at 90 and it's not pushing too hard to get there.
off road it's brilliant
in a 1.3 running 30's i'd be looking at 4.9's
Post Posted: Sat Sep 12, 2009 6:43 pm
i don't understand why people don't like to rev Suzuki motors. my 1.6 is happy to rev at 4 grand all day. the red bit on the gauge doesn't start until 6500 so 4000 is stuff all.
rev em cos they love it. :wink:
Post Posted: Sat Sep 12, 2009 6:48 pm
8)
Post Posted: Sat Sep 12, 2009 8:18 pm
8)
8)
Post Posted: Sat Sep 12, 2009 9:10 pm
8)
8)
8) :wink: :roll: :lol:
Post Posted: Sat Sep 12, 2009 9:15 pm
My Gv sitts on about 3500 at 100kph, but then I change out of 3rd to 4th.
You guys would obliterate me off road tho, unless it was dirt roads, then no chance !!!! peaceout :finger: peaceout pompoms :finger: pompoms
Post Posted: Sun Sep 13, 2009 7:25 pm
8)
8)
8) 8) 8)
Post Posted: Sun Sep 13, 2009 7:32 pm
Taff wrote:
8)
8)
8) 8) 8)
it is true though, the motor isn't a primitive push rod motor. hell i have had
Suzuki motors that would do 12000revs all day every day.
Post Posted: Sun Sep 13, 2009 7:43 pm
I run 30" tyres, 6.5 gears and 3.9 diff.
100 is around 4000rpm, it loves it.
Post Posted: Tue Sep 22, 2009 3:01 am
So with the 6.5's is it a must to the run brace on the transfer ? Is it hard to fit the brace.
cheers
My Maruti build, Click WWW
Post Posted: Tue Sep 22, 2009 11:30 pm
6.5's will bend the stock transfer arms if you have a 1.3.
I brace the longside arm by boxing it in, run urethane isolation mounts and a small tab off the longside arm that picks up 2 of the front output housing bolts.
This seems to be enough.
Here's a photo of a braced arm.
PS 1.0 litre sierras have 4 transfer mounts and don't seem to bend arms, regardless of gears or tyre size.
Post Posted: Wed Sep 23, 2009 3:43 pm
Am I blind or has this not been done in that photo?
Post Posted: Wed Sep 23, 2009 9:36 pm
yer maybe it's on the other side?
Post Posted: Wed Sep 23, 2009 10:45 pm
I doubt it.
How/why would a bracket reach past the shifter to the front output bolts?
Post Posted: Wed Sep 23, 2009 11:03 pm
boys I dont think that pic has the extra bracket, but im sure if you use you imagination youll work it out.
the rocky road beefed up arms use something similar with the extra bracket, but they use the rear output of the tc
Post Posted: Wed Sep 23, 2009 11:29 pm
Spidertrax transfer mount has served me well with 6.5 gears and double locked on 33's
Post Posted: Wed Sep 23, 2009 11:53 pm
So your Got33`s now??? :lol:
Post Posted: Wed Sep 23, 2009 11:57 pm
Had Silverstone 33's now have Simex 32's...
Silverstone 33's were 31.5"
Simex 32's are 32.8"
Will be Want35s soon.
Post Posted: Thu Sep 24, 2009 1:14 am
thats just gready jas :wink:
Post Posted: Thu Sep 24, 2009 1:57 am
:rofl: That`s what i thort to.
Users browsing this forum: Google [Bot] and 142 guests
