It is currently Wed Sep 23, 2026 4:36 am
Vehicle: 1999 Suzuki Jimny
Post Posted: Sat Apr 02, 2016 9:38 am
Hey guys was just wondering what i could do to fix my 4x4, it wont engage not manual hubs and i have checked all the lines im pretty sure just dont know what it could be any help would be much appreciated
CheersImage
Sent from my SM-N9005 using Tapatalk
Post Posted: Sat Apr 02, 2016 9:49 am
First things first
Is the front driveshaft spinning when you put the shifter into 4WD? If yes, then it's not the transfer case. You can check this by putting the car in 4WD when stationary and trying to turn the front driveshaft. If it DOESN'T turn, the transfer case is engaged.
What do you mean "not manual hubs" do you mean it has stock auto (vacuum actuated) hubs? if so these are problematic and at 17 years of age will need a service or replacement with reliable manual hubs.
If you mean "it's not the manual hubs" then blowing out the lines won't help, you may have other issues with the front end.
A bit more information in the question would have helped us more.
MOD: Edited to make sense
Post Posted: Sat Apr 02, 2016 12:44 pm
You can check this by putting the car in 4WD when stationary and trying to turn the front driveshaft. If it turns, the transfer case is engaged.
If it's engaged shouldn't it not turn :?
Post Posted: Sat Apr 02, 2016 12:46 pm
Ah yes, my bad. I knew what I meant. :oops:
Post Posted: Sat Apr 02, 2016 1:14 pm
Post Posted: Sat Apr 02, 2016 4:30 pm
So if the drivehshaft turns its not engaged?
Post Posted: Sat Apr 02, 2016 5:01 pm
If the transfer is in 4WD and the front driveshaft can be turned freely then the transfer isn't engaging 4WD.
If the driveshaft can't be turned but there is no drive to the wheels the problem is diff/hubs
Are you still running the factory vacuum actuated hubs?
Users browsing this forum: Google [Bot] and 201 guests
