[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
bailey.robey
Vehicle: 1999 Suzuki Jimny
 Posted: Sat Apr 02, 2016 9:38 am |
Hey guys was just wondering what i could do to fix my 4x4, it wont engage not manual hubs and i have checked all the lines im pretty sure just dont know what it could be any help would be much appreciated Cheers  Sent from my SM-N9005 using Tapatalk
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13011 Location: Melbourne
 Posted: Sat Apr 02, 2016 9:49 am |
First things first
Is the front driveshaft spinning when you put the shifter into 4WD? If yes, then it's not the transfer case. You can check this by putting the car in 4WD when stationary and trying to turn the front driveshaft. If it DOESN'T turn, the transfer case is engaged.
What do you mean "not manual hubs" do you mean it has stock auto (vacuum actuated) hubs? if so these are problematic and at 17 years of age will need a service or replacement with reliable manual hubs.
If you mean "it's not the manual hubs" then blowing out the lines won't help, you may have other issues with the front end.
A bit more information in the question would have helped us more.
MOD: Edited to make sense
Joe
Joined: Sat Jul 04, 2009 11:30 pm Posts: 49041 Location: Rockingham W.A
 Posted: Sat Apr 02, 2016 12:44 pm |
Gwagensteve wrote: You can check this by putting the car in 4WD when stationary and trying to turn the front driveshaft. If it turns, the transfer case is engaged. If it's engaged shouldn't it not turn
_________________ Joe likes boobs ( . )( . ) ( ° )( ° )
Gwagensteve
 Posted: Sat Apr 02, 2016 12:46 pm |
Ah yes, my bad. I knew what I meant.
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Sat Apr 02, 2016 1:14 pm |
Joe wrote: Gwagensteve wrote: You can check this by putting the car in 4WD when stationary and trying to turn the front driveshaft. If it turns, the transfer case is engaged. If it's engaged shouldn't it not turn  Gwagensteve wrote: Ah yes, my bad. I knew what I meant.  Edited to make sense
bailey.robey
 Posted: Sat Apr 02, 2016 4:30 pm |
So if the drivehshaft turns its not engaged?
Gwagensteve
 Posted: Sat Apr 02, 2016 5:01 pm |
If the transfer is in 4WD and the front driveshaft can be turned freely then the transfer isn't engaging 4WD. If the driveshaft can't be turned but there is no drive to the wheels the problem is diff/hubs
Are you still running the factory vacuum actuated hubs?
[ 7 posts ] |
Users browsing this forum: Bing [Bot], Google [Bot] and 195 guests
