It is currently Sat Aug 08, 2026 6:35 am
Vehicle: 1991 Suzuki Sierra JX
Post Posted: Thu Jul 21, 2016 12:52 pm
Hey guys,
I understand that the guard chop is the best way to go about getting 33s on a Sierra. However, will a 2" body lift make it possible without any chopping, maybe just some hammering??
Thanks in advance.
Post Posted: Thu Jul 21, 2016 3:57 pm
Got 33" on my little play car with 2" body and 2" lifted springs and had to chop the front.
Post Posted: Thu Jul 21, 2016 9:31 pm
Bodylift + hammer
They fit easy, offset and tyre width is critical to get them on with minimal work. May also be necessary to redrill your diff spring perches to bring the diff forward 20mm away from the firewall depanding on your spring length
Post Posted: Fri Jul 22, 2016 5:01 pm
Ah damn, might be better off just getting 31s then haha thanks guys!
Post Posted: Tue Jul 26, 2016 4:14 pm
Even with a 2" body lift, it's likely you'll need some massaging of the guards to achieve full lock/travel.
Post Posted: Tue Jul 26, 2016 6:33 pm
This is 31's with 2" body lift and guards massaged.
Post Posted: Tue Jul 26, 2016 7:56 pm
32"s no body lift, some hammer work and 50mm susp lift
.Image
Post Posted: Wed Jul 27, 2016 12:06 pm
And bumpstop spacing?
Post Posted: Wed Jul 27, 2016 1:45 pm
Yup only in the front, the rear tucks right up no dramas.
To be honest i could probably reduce the front bumps a bit they are only there as a buffer to stop the shocks bottoming however ive found them nice on steep inclines as the car just sits hard on them and doesnt bounce around
Post Posted: Wed Jul 27, 2016 5:04 pm
Or run 6" lift and 33s (pic stolen from fb)
Post Posted: Wed Jul 27, 2016 5:16 pm
on a coily too! Check those steering angles =P
Post Posted: Wed Jul 27, 2016 6:32 pm
I love Facebook. Apparently, regardless of how tall you've made your car it's:
A) Just as stable as stock
B) More stable than stock
C) If you roll it you can't drive
D) It's fine if you're a good driver
E) It's fine once you get used to it
F) All of the above
Post Posted: Wed Jul 27, 2016 6:52 pm
F) All of the above
It's where all the cool kids get their info from :rofl:
Post Posted: Wed Jul 27, 2016 7:50 pm
Haha a good way to make your car less capable than stock
Vehicle: 98 Jimny
Post Posted: Fri Jul 29, 2016 1:20 pm
But now you can go mud bogging and contemplate putting a V8 in it because of all the extra space for the sump!
Vehicle: Vitara 1994
Post Posted: Sat Jul 30, 2016 11:16 pm
There is no way they are 33's?
I remember when I bought my first sierra I nearly bought a poser spec sierra with a 6 inch on 37's.....I still thought the car was too tall for the tyres! Maybe they are 33's
Post Posted: Sun Jul 31, 2016 1:29 pm
What's the reasoning behind not cutting guards?
Post Posted: Wed Aug 03, 2016 1:01 am
Thanks for the input guys! I'm all good with a bit of hammer work, I just don't have the skills or time to be cutting and welding; she's been off the road for too long and I just wanna start wheeling it again haha
Users browsing this forum: No registered users and 63 guests
