| Author |
Message |
Brooksy
Vehicle: 1991 Suzuki Sierra JX
 Posted: Thu Jul 21, 2016 12:52 pm |
Hey guys,
I understand that the guard chop is the best way to go about getting 33s on a Sierra. However, will a 2" body lift make it possible without any chopping, maybe just some hammering??
Thanks in advance.
Bruce
Joined: Sun Jun 11, 2006 11:30 pm Posts: 4003 Location: Brisbane
 Posted: Thu Jul 21, 2016 3:57 pm |
Got 33" on my little play car with 2" body and 2" lifted springs and had to chop the front.
_________________ [quote="royce"] I wouldnt mind insulating my rear
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Thu Jul 21, 2016 9:31 pm |
Bodylift + hammer They fit easy, offset and tyre width is critical to get them on with minimal work. May also be necessary to redrill your diff spring perches to bring the diff forward 20mm away from the firewall depanding on your spring length
Brooksy
 Posted: Fri Jul 22, 2016 5:01 pm |
Ah damn, might be better off just getting 31s then haha thanks guys!
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13008 Location: Melbourne
 Posted: Tue Jul 26, 2016 4:14 pm |
Even with a 2" body lift, it's likely you'll need some massaging of the guards to achieve full lock/travel.
bogga
Joined: Sun Sep 20, 2009 11:30 pm Posts: 704 Location: Coffs Harbour
 Posted: Tue Jul 26, 2016 6:33 pm |
This is 31's with 2" body lift and guards massaged.
MrRocky
 Posted: Tue Jul 26, 2016 7:56 pm |
32"s no body lift, some hammer work and 50mm susp lift .
JrZook
 Posted: Wed Jul 27, 2016 12:06 pm |
MrRocky wrote: 32"s no body lift, some hammer work and 50mm susp lift
And bumpstop spacing?
MrRocky
 Posted: Wed Jul 27, 2016 1:45 pm |
Yup only in the front, the rear tucks right up no dramas. To be honest i could probably reduce the front bumps a bit they are only there as a buffer to stop the shocks bottoming however ive found them nice on steep inclines as the car just sits hard on them and doesnt bounce around
jdk81
Joined: Sat Jul 18, 2009 11:30 pm Posts: 2372 Location: Ballarat, VIC
 Posted: Wed Jul 27, 2016 5:04 pm |
Or run 6" lift and 33s (pic stolen from fb)
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Wed Jul 27, 2016 5:16 pm |
on a coily too! Check those steering angles =P
Gwagensteve
 Posted: Wed Jul 27, 2016 6:32 pm |
I love Facebook. Apparently, regardless of how tall you've made your car it's:
A) Just as stable as stock
B) More stable than stock
C) If you roll it you can't drive
D) It's fine if you're a good driver
E) It's fine once you get used to it
F) All of the above
Bruce
 Posted: Wed Jul 27, 2016 6:52 pm |
Gwagensteve wrote: I love Facebook. Apparently, regardless of how tall you've made your car it's:
F) All of the above It's where all the cool kids get their info from
MrRocky
 Posted: Wed Jul 27, 2016 7:50 pm |
Haha a good way to make your car less capable than stock
Kor3y101
Joined: Tue Aug 18, 2015 6:50 pm Posts: 613 Location: Ipswich
Vehicle: 98 Jimny
 Posted: Fri Jul 29, 2016 1:20 pm |
But now you can go mud bogging and contemplate putting a V8 in it because of all the extra space for the sump!
vet 180
Vehicle: Vitara 1994
 Posted: Sat Jul 30, 2016 11:16 pm |
jdk81 wrote: Or run 6" lift and 33s (pic stolen from fb)  There is no way they are 33's? I remember when I bought my first sierra I nearly bought a poser spec sierra with a 6 inch on 37's.....I still thought the car was too tall for the tyres! Maybe they are 33's
shakes
Joined: Sat Apr 10, 2010 11:30 pm Posts: 4895 Location: Northcote
 Posted: Sun Jul 31, 2016 1:29 pm |
What's the reasoning behind not cutting guards?
Brooksy
 Posted: Wed Aug 03, 2016 1:01 am |
Thanks for the input guys! I'm all good with a bit of hammer work, I just don't have the skills or time to be cutting and welding; she's been off the road for too long and I just wanna start wheeling it again haha
