| Author |
Message |
Gussyb
Vehicle: Holden Drover, Suzuki LJ81
 Posted: Wed Sep 23, 2020 5:19 pm |
Hi. I'm trying to get the parking lights on my Drover working. I have tested the lights with a circuit tester and it didn't light up. I measured the volts with a volt meter and it was reading as 0.20 volts. I heard that corrosion can cause the volts to drop but can they cause them to drop that much and what should I do to try and fix it. Thanks Gus
_________________ Done myself a mischief.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13007 Location: Melbourne
 Posted: Wed Sep 23, 2020 5:46 pm |
0.2V is just noise. It's not a meaningful reading. Checked the fuse? Checked the taillights?
Gussyb
 Posted: Wed Sep 23, 2020 5:59 pm |
fuse is all good but the tail lights blow the fuse. Gus
Gussyb
 Posted: Wed Sep 23, 2020 6:00 pm |
I should say that the headlight fuse is all good but the tail lights blow the tail/brake light fuse Gus
Gwagensteve
 Posted: Wed Sep 23, 2020 6:01 pm |
They're on the same circuit as the park lights.
Gussyb
 Posted: Wed Sep 23, 2020 6:12 pm |
thanks now I need to find what 's causing the fuse to blow. Cheers Gus
fordem
Joined: Mon Apr 19, 2010 11:30 pm Posts: 2656 Location: Georgetown, Guyana
 Posted: Wed Sep 23, 2020 8:32 pm |
Be aware - tail lights & brake lights are not quite the same thing - and in this case they are on two separate circuits with separate fuses.
So - one globe with two filaments on separate circuits - presumably it's the side/park light fuse that is blowing, that powers front & rear park lights, as well as dash lights.
Now - what bother me is that you appear to have a very unusual view of electrical concepts, you might want to find someone to guide you through the troubleshooting.
Gussyb
 Posted: Thu Sep 24, 2020 9:57 am |
fordem wrote: Be aware - tail lights & brake lights are not quite the same thing - and in this case they are on two separate circuits with separate fuses. this is my fuse box cover
Gussyb
 Posted: Thu Sep 24, 2020 11:22 am |
Here’s the photo of my fuse box cover
Gussyb
 Posted: Thu Sep 24, 2020 11:25 am |
Attachment: D954CFFB-5BF7-430C-82AB-D6BB33B47F21.jpeg
fordem
 Posted: Thu Sep 24, 2020 12:41 pm |
What can I say - EVERY diagram I've seen for those vehicles shows two different fuses.
Gwagensteve
 Posted: Thu Sep 24, 2020 12:43 pm |
Stop/tail fuse will kill the park lights as has been described.
