It is currently Sun Sep 20, 2026 12:57 am
Vehicle: Holden Drover, Suzuki LJ81
Post Posted: Wed Sep 23, 2020 5:19 pm
Hi. I'm trying to get the parking lights on my Drover working. I have tested the lights with a circuit tester and it didn't light up. I measured the volts with a volt meter and it was reading as 0.20 volts. I heard that corrosion can cause the volts to drop but can they cause them to drop that much and what should I do to try and fix it.
Thanks
Gus
Done myself a mischief.
Post Posted: Wed Sep 23, 2020 5:46 pm
0.2V is just noise. It's not a meaningful reading.
Checked the fuse?
Checked the taillights?
Post Posted: Wed Sep 23, 2020 5:59 pm
fuse is all good but the tail lights blow the fuse.
Gus
Post Posted: Wed Sep 23, 2020 6:00 pm
I should say that the headlight fuse is all good but the tail lights blow the tail/brake light fuse
Gus
Post Posted: Wed Sep 23, 2020 6:01 pm
They're on the same circuit as the park lights.
Post Posted: Wed Sep 23, 2020 6:12 pm
thanks now I need to find what
's causing the fuse to blow.
Gus
Post Posted: Wed Sep 23, 2020 8:32 pm
Be aware - tail lights & brake lights are not quite the same thing - and in this case they are on two separate circuits with separate fuses.
So - one globe with two filaments on separate circuits - presumably it's the side/park light fuse that is blowing, that powers front & rear park lights, as well as dash lights.
Now - what bother me is that you appear to have a very unusual view of electrical concepts, you might want to find someone to guide you through the troubleshooting.
Post Posted: Thu Sep 24, 2020 9:57 am
this is my fuse box cover Image
Post Posted: Thu Sep 24, 2020 11:22 am
Here’s the photo of my fuse box cover Image
Post Posted: Thu Sep 24, 2020 11:25 am
Post Posted: Thu Sep 24, 2020 12:41 pm
What can I say - EVERY diagram I've seen for those vehicles shows two different fuses.
Post Posted: Thu Sep 24, 2020 12:43 pm
Stop/tail fuse will kill the park lights as has been described.
Users browsing this forum: No registered users and 63 guests
